The stablizers on my 320 don’t really reach the ground. This could be by design since some campgrounds “require” some type of pad under the stablizer foot in order to minimize damage to the campground surface. I purchased 4 solid lawnmower wheels for a few dollars and attched them to the stablizer feet giving them an extra inch as well as some cushion effect. I had to drill some holes for golts to secure them. Picture attached.
Odessa, Fl.
Did you secure each wheel with a single bolt, or two bolts? It looks like one from the photo, but the shading may be making the second hard to see. Also, did you drill through the stabilizer pad first so that you could then use that hole to mark where to drill through lawnmower wheel? I like the idea and may use it. Appears pretty straight forward, but if you encountered any issues or have any tips for this mod, I would appreciate you posting them. Thanks.
The second photo shows how all 3 pieces of the plywood are held together with a bolt. The footprint doesn't seem to hold debris.
With over 7K miles since this mod, all seems to be holding up well, I may make something prettier when the weather breaks.
2019 320 Boondock Edge - Sold Jan 2022
