2018 tab 400 wheel specs?
I'm interested in replacing the stock wheels/  rims and wondering if anyone can tell me what specs I need to ensure correct fit in addition to the diameter and number of lugs?
2018 T@B 400
  • Denny16
    Denny16 Member Posts: 5,431
    You need the width and rim offset (if any).  Take your existing wheel and tire to a wheel/tire dealer and they can advise you of what’s available.  I did a search on the tire size, and the results were somewhat limited for trailer tires, Goodyear seems like a good choice, with good reviews.  The Boondock wheel is the same diameter, but slightly wider, and you can use small truck tires on it.
  • SeaLaVie
    SeaLaVie Member Posts: 47
    The only thing I know at this point is it's a 15 inch wheel with 5 lugs. So far the trailer wheels I've seen advertised are 5 inch or 6 inch width and 4.5 in lug circle. I'm going to email nucamp and see if they will get me the exact info I need. Will post what I hear back from them.
    What I'm thinking about doing is buying some standard rims that will accept a babymoon hubcap. I will paint the rims to match the tab trim. Going for the Retro look.
    2018 T@B 400
  • SeaLaVie
    Got my answer it looks like. Took some pictures of the backside of the wheel looks like a 5 inch width. Not a hundred percent sure of the lug distance yet.
    2018 T@B 400
