2018 tab 400 wheel specs?
SeaLaVie
Member Posts: 47
I'm interested in replacing the stock wheels/ rims and wondering if anyone can tell me what specs I need to ensure correct fit in addition to the diameter and number of lugs?
2018 T@B 400
You need the width and rim offset (if any). Take your existing wheel and tire to a wheel/tire dealer and they can advise you of what’s available. I did a search on the tire size, and the results were somewhat limited for trailer tires, Goodyear seems like a good choice, with good reviews. The Boondock wheel is the same diameter, but slightly wider, and you can use small truck tires on it.
The only thing I know at this point is it's a 15 inch wheel with 5 lugs. So far the trailer wheels I've seen advertised are 5 inch or 6 inch width and 4.5 in lug circle. I'm going to email nucamp and see if they will get me the exact info I need. Will post what I hear back from them.
What I'm thinking about doing is buying some standard rims that will accept a babymoon hubcap. I will paint the rims to match the tab trim. Going for the Retro look.2018 T@B 400 -
Got my answer it looks like. Took some pictures of the backside of the wheel looks like a 5 inch width. Not a hundred percent sure of the lug distance yet.
2018 T@B 400
- 920 Introductions
- 74 Teardrop Groups & Links
- 915 Tips & Tricks
