Is this in the Solo edition? I think that space is no longer available since it ran in a tube under the bed.Redfish24 said:So I am curious since the sewer hose storage area is no longer on the 2021 Tab 400 where is one supposed to stow this lovely device away at? Might have to try using the Poop Chute bags to keep it cleaner. I needed a laugh on a Monday morning.
How long of a sewer hose can you fit in the 8 gallon action packer? Also how many bolts did you mount yours with and do you happen to have a picture of it mounted. I'm considering mounting one or two when I get my trailer.VictoriaP said:Welcome to the world of the 320, which has never had built in storage for that hose. Searching this forum will give you at least a dozen ideas, some of them pretty ingenious.I went the simple route. Since I have the Boondock platform, I just coil mine into one of the ActionPacker tubs I bolted to the platform. Using Happy Campers toilet chemical—which is nothing short of a miracle—everything breaks down fast, and I’m not kidding, there is ZERO smell. (And no nasty chemical fragrance).While permanent storage would be nice to have, in my book, it’s a total non issue to be without it, enough so that even those ingenious mods aren’t on my priority list as I prep the trailer for this camping season. Maybe next fall.
I have a 15’ in there now. No pics, it’s just a couple of holes drilled in the bottom of each Action Packer, spaced to match the holes on the platform. Bolts inserted from below, with large rubber and metal fender washers to protect aluminum of the platform and spread the load, and wing nuts inside the bins.bergger said:How long of a sewer hose can you fit in the 8 gallon action packer? Also how many bolts did you mount yours with and do you happen to have a picture of it mounted. I'm considering mounting one or two when I get my trailer.VictoriaP said:Welcome to the world of the 320, which has never had built in storage for that hose. Searching this forum will give you at least a dozen ideas, some of them pretty ingenious.I went the simple route. Since I have the Boondock platform, I just coil mine into one of the ActionPacker tubs I bolted to the platform. Using Happy Campers toilet chemical—which is nothing short of a miracle—everything breaks down fast, and I’m not kidding, there is ZERO smell. (And no nasty chemical fragrance).While permanent storage would be nice to have, in my book, it’s a total non issue to be without it, enough so that even those ingenious mods aren’t on my priority list as I prep the trailer for this camping season. Maybe next fall.
