Fresh water tank refill
My 2016 CS-C T@B fresh water tank doesn't seem to fill. The fill at the tow end on the driver's side accepts 1 gal then overflows. No water advances into the system w/the water pump. No leaks, only a slow drip in front of the axle on left side. I drained the freshwater tank (I think) to measure the amount of water I poured in & used a container instead of a hose to control & confirm the amount poured in.  Using the city water connection w/pressure control the water flows as it should to the faucets, shower & toilet, but I can't get the fresh water tank to fill. I've turned on the pump after adding 1 1/2 gal. & it continues to run but nothing from the faucets, shower or toilet. Advice please.  I want to travel & shower when I get to camp using the fresh water tank. Thanks much, this group has helped me before so here I am again for good advice.
Sabastian 2016 CS-S T@B
TV Subaru Forester
