I have a 2016 T@B with an Alde system and the manual controller. I turned on the heat while camping in the mountains of NH using battery and propane. After about 1 hr, the red light went on, which means no propane. My propane had been rather full when I left home, but I went to check, and it was completely empty. I replaced it, set everything back up, and after about 1 hr, same red light, propane tank was empty again! Does anyone know what I did wrong? I am sure this worked much better last year!
2014 Little Guy T@B S Max
0 ·
San Diego, CA
www.airbossone.com
I found that the road vibration loosened it and allowed our propane to leak out.
We no longer use the in-line gauge!
Just a suggestion...
Thank you all for your replies and after reviewing and considering your suggestions and comments, I wonder if the connection to my gauge had frozen? I have an external gauge that I know isn’t the most accurate, but as long as it is in the green when I leave home I am usually okay. When I left home it was in the green and the temperature in the 50s. I hadn’t used my propane a whole lot during the summer, so I figured it’d be good for 2 days. When I got to the White Mountains in NH, the temperature was about low 30s. The gauge was the way I had left it; green. I heated some dinner and turned on the heat. All was progressing nicely, it was feeling warmish, then the red light went on, solid. My manual stated I was out of propane. I checked the gauge and it was in the empty zone. I turned on the gas stove, no propane there either. So I figured the tank was empty. I don’t use the heat overnight anyhow, so I turned off the heat and snuggled up in my sleeping bag and read, then slept. Next morning, no coffee :( . I went to the gas station in Lincoln with my tank, which was very lightweight. He lifted it and told me it felt empty (super scientific). He sold me a ‘full’ one for a hefty price, and it was heavier - though not as heavy as I thought it should be because I could actually easily lift it which isn’t usually the case. But, it was definitely heavier, and when I installed it, the gauge showed green so I was happy. I turned on the Alde, all went well, I made tea, and after a bit, the solid red light went on. My gauge read empty. This is where I gave up. I had plenty of clothes and bedding and books and places to explore, so who needs heat?
The next morning I drove home to CT and this morning, I finally checked my gauge. It’s very much in the green, more so than when I had first left home, so I am assuming the tank is very full. I turned on the Alde, and since it’s 60 degrees here, the camper warmed up quickly, so the light didn’t go red. I guess I have to go camping in the mountains again to really test this!
Now I am wondering, can something freeze near the propane tank (maybe the gauge connection)? I probably should have removed it and tried again, but I didn’t consider that at the time. Since it doesn’t seem to be the Alde or the propane tank, all I can think of is that the cold weather froze something somewhere. ???
I am of the opinion that those propane gauges are inaccurate at best. There are several other ways to gauge the propane level in a tank but they also seem to have issues of one type or another.
Although it is somewhat annoying, I have found there best way to get a reasonably accurate gauge of propane level is to weigh the tank. Propane weighs about 4.24 pounds per gallon. The Tare Weight (TW) of the tank will be marked on the side of the tank. A steel tank will have a TW of about 18 pounds. Therefore, a full tank of propane should weigh about 38 pounds. You'll probably find that an exchange tank from Lowe's or Home Depot will weigh somewhat less--maybe 33 pounds--because they only put 4 gallons of propane in those tanks rather than a full 5 gallons.
You can buy a hand scale on line or in many stores. Luggage scales work well.
+1 what @falcon1970 said. The only real way is to weigh it...
Also, as I mentioned, I too used one of those inline gauges, and then I found that it had vibrated loose and had leaked my propane out... That might be what happened to yours.
Also, I wonder if the second time you had a red light indicator, if perhaps your battery was low. I believe that's another cause for that red light.
https://www.rvtravel.com/hooking-up-an-refilled-lp-cylinder-check-this-out/
https://www.rvtravel.com/rv-doctor-thumping-propane-regulator/
