I am an owner of a 2009 (new to me) Dutchman T@B. Battery is deep cycle marine. No problems with operations through my fall camping. Following some advise, I installed a top post knife switch disconnect. In doing so, I unhooked at terminals with some resulting confusion. I borrowed an experienced friend who helped me reinstall battery and we confirmed with voltage check that battery disconnect working as intended. Getting ready for quick close to come camp out. Make connection at post knife switch but now no power inside trailer. I have connection for battery and a solar panel (installed on roof line by prior owner at dealership) running from battery to inside read out. We had connected two positives and two negatives on correct posts and confirmed with voltage. Again should have been simple reconnect by making the connection via post knife disconnect. What am I missing? Can anyone send images so I can see proper set up.
0 ·
Typically, but not always, the ground wire will be white, whereas the positive wire is typically red or black. (I do not know specifically why nuCamp has a red wire connected to green, but I am guessing that they buy the inline fuse as a separate item and connect it to the red positive wire from the trailer.)
I agree with the comments of both @Denny16 and @ScottG. Most likely a fuse is blown. First, check the fuse that is at the battery (if you have an inline fuse on the positive wire.) If that is OK, then check the fuses at the converter as @ScottG suggested. Once you get everything working again, I recommend that you mark the negative wire with a Sharpie pen as shown in the second photo.
IMPORTANT, to help avoid blowing a fuse, or causing an accidental spark/shock:
(1) When disconnecting wires from a battery, remove the negative wire first, and then remove the positive wire. (i.e., "negative off first.")
(2) When connecting wires to a battery, attach the positive wire first, and then connect the negative wire. (i.e., "negative on last.")
