SPARE TIRE UNDER TONGUE ON 320
gulfarea
Member Posts: 524
I see in the new video that Nu-Camp might be putting spare tire under the trailer tong in the 320 like the 400 does. Anyone tried this? Art
2019 TaB 320 S Boondock Edge
A moment-arm analysis of the impact of moving the spare wheel and tire two feet forward revealed that this will more than double its contribution to the tongue weight. Something to consider.
2019 T@B 320-S Boondock Edge.2015 Jeep Grand Cherokee Overland with 5.7L Hemi0 -
...not to mention ground clearance...TV- '16 Chevy Colorado LT Crew Cab-DuraMax
2018 320S Outback1 -
I have a skinny donut spare mounted under the tongue box, that utilizes a wind down/up mechanism. I find it to be a very practical modification to our 320, that solves a lot of issues. I have previously posted details for anyone that may be interested...0
I think the ground clearance would be the problem. I'd immediately move it, if it came to me that way from the factory. We've already bashed the tongue jack shaft twice on two high driveway entrances.
Chan - near Buffalo NY
A_Little_T@b'll_Do_Ya0 -
ChanW said:I think the ground clearance would be the problem. I'd immediately move it, if it came to me that way from the factory. We've already bashed the tongue jack shaft twice on two high driveway entrances.I agree with you -I'd remove it toYou might try this :https://tab-rv.vanillacommunity.com/discussion/10557/no-more-bent-jacks-installing-a-jack-e-up-on-a-320-boondock#latest
TV:2019 Nissan Frontier PRO-4X With an Old Man Emu liftTrailer: 2019 T@B 320 Boondock with a Lock&Roll Coupler & Jack-e-upCustom fabricated metal bottom claddingCalifornia, USA0 -
Just bought a 2021 T@B 320S and the spare is under the tongue. Not anxious to crawl under there in the event of a flat.0
@marjamr, If the tire lift works like the 400’s, you use the manual tool provided to lower the tire from under the tongue. When done, raise it back. I think the mechanism is on the door side, the passenger side of the tongue.If you have it, read the caution—do NOT use a drill to raise and lower the tire.Verna, Columbus, IN
Verna, thanks. I’ll check that. When I peeked under the tire it looked like a large wing nut was holding the tire on. Similar to the spare tires you see in many car trunks. I checked the tongue box but didn’t see any tire lowering device in there.0
@marjamr
Look on the right hand side of the frame rail just barely aft of the tub. There will be something looking like a 19mm hex nut with a label saying which way to turn it to lower or raise the tire. BTW, when the tire lands on the ground you still need to lower the winch some more in order to get enough slack in the cable to remove the "wing nut" from the tire.
You should have received a small ratchet wrench with your trailer. Use that to raise and lower the tire.
OK, having said that last and adhered to the official school-approved solution, let me add that you actually CAN use a battery powered drill to operate the spare tire winch as well as the stabilizers. The caveat being that you USE A SLOW SPEED ON THE DRILL. The idea of the drill is not to do it faster but to avoid (for us decrepit old geezers) all that hand cranking. If you try to use a drill at high speed on the spare tire winch I can almost guarantee you will end up with a snarled cable. And unsnarling it is worse than trying to undo all the knots in a three year old's shoelaces.3 -
Thanks, @falcon1970. It’s hard being a recliner chair pilot at times!😂😂.I have two choices to get to the T@B and both of them entail a 30% grade either in my yard or 2nd driveway😂. It’s too steep for these knees after dark!Verna, Columbus, IN
Has anyone tried to find a compact spare for a 320??0
On my 320S 2021 the spare resides within the tongue "A" and hangs down only a few inches. If this hits anything there will be other issues. I've found lowering the tire to use isn't real hard but getting it lined up to return requires some work. I much prefer this location as it allows other uses for the front deck than putting a (rarely used) tire there. Tongue weight change is valid for moving from the back but should be about the same as mounted on the front carrier. I'm glad I never had to deal with clearance and accessibility issues of the former low back position.
Snohomish WA, 2024 3.6L Grand Cherokee
managed by VE Smart Network1 -
Thanks. Makes sense. I also have a 2021 320S. You say that lowering the tire isn't real hard. I don't understand what the procedure is. An earlier post mentions "a 19mm hex nut with a label saying which way to turn it to lower or raise the tire." Not clear what TAB model is being referenced. There is no such thing on my trailer. What I see lying on my back is in the attached image. There is what looks like a big wing nut in the middle that appears to be holding the tire in place. Am I really supposed to loosen that and risk having the tire fall on me?
Hi, On my 320, the access point to lower the tire is inside the front center tub at the bottom. There is a hole that you place the tool (same one that lowers the stablizers). You place the tool through the hole and crank. The tire will lower. Best wishes...2025 360 CS
Southern Maryland1 -
I also have a 2021 320 @pmfarrell099 and the access to lower the spare is in the cargo box; it uses the same size nut as the stabilizers, just as @Yoshi_TAB describes. It's near the front wall and just to the passenger side of the propane tank. Here are some photos that may help.
The bolt on the retaining ring for the propane tank should face the opposite way from the above photo for easier access - here's a shot with the bolt in that orientation.
2021 T@B 320 S Boondock / 2022 Telluride - Phillies/Eagles/Flyers Country2 -
Very helpful. Thank you.1
Thanks for this post.
Our '25 320 Boondock Black canyon came with the spare under the tongue. No issues so far.
