Why I won't run my fridge on LP whole driving
2»
    edited June 2015
    I've found the specs for the 12v power draw (in the manual - fancy that):
    DC Operation -- 12 volts DC voltage
    Power Used
    11.7 Amps @ 12 volts DC
    13.6 Amps @ 14 volts DC
  • twocutestwocutes Member Posts: 198
    Jenn - could you post a link to the remote thermometer you bought?
    Beth
    Minnesota
    Practicing to be a wanderer
    2020 T@B 320 CSS Boondock Lite
    2014 T@B 320 CSS M@xx
    2020 Jeep Wrangler Unlimited 8 speed automatic
    2020 Jeep Grand Cherokee Limited V8
    2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
    Just a thought, if you have the CS model with the 12v/120v model, it's compressor-based, and only draws 5-6 amps when its running.  This should be handled easily by the charge wire in the trailer hookup.
    T@@bulous
    2014 T@B CS Maxx
    Martha Lake, WA
    The Jeep, with no trailer attached gets between 13.79-14.00 just idling in the driveway. The fridge on battery, shows below 12.0 (can't remember) on the cigarette lighter voltmeter, and about 12.18-12.25 when connected to the Jeep idling, and the fridge is on its coldest setting. That is pretty close to the 11.7 Chan cited. The Jeep is probably putting out slightly higher voltage when it is on the highway, but, not enough to overcome the usage. Is there likely a variance in the numbers in the manual for the Norcold?
    I don't see myself putting money into upgrading the alternator, at this time. I will likely be doing what PXLated does. The ability to run the Norcold on propane makes it valuable enough for me to work around this issue, for now. It does a great job on propane.
  • SweetlyHomeSweetlyHome Member Posts: 336
    I have been following this and similar threads with interest.  The next time I camp I plan on taking voltage measurements as Jen has done.  What I want to also check is the voltage at the TV battery when the Norcold is running.  If there is much of a difference between the TV and the T@B indicates the wire from the TV battery to the connector at the hitch is too small.
    Beth, it just arrived sonorant vouch for it, yet, but in the Amazon reviews several folks were pleased with it for monitoring their RV fridge. http://www.amazon.com/gp/product/B004QJVU78?psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s01
    edited June 2015
    Jenn, I was talking 11.7 amps, not volts....
    What you're seeing, 12.1V-12.3V in the Tab, while at idle,  might not be unreasonable. What it reads in the Tab at higher rpm is what matters most, as well as the voltage drop between the TV battery and the 7 pin connector.
    You probably should look for 13-13.5V (or higher) at the 7pin (with the Tab hooked up and the fridge running) when at higher RPMs. It probably won't be that high when idling though.
