Hi Folks,
I winterized the Alde by driaing all the water out and then filling the fresh water tank with 3 gallons of RV antifreeze, then pumped it through the shower and sink taps. We are at the point where we want to go do some boondocking but don't want to de-winterize yet.
I'm pretty sure you can still run the Alde off propane for heat (no water) and not damage anything?
Also what happens if say the propane runs out at night while running the heater, will the system just auto shut down safely?
0 ·
The only thing is to be sure that the Alde bypass valves were set correctly when you put the antifreeze into the system.
Alde doesn't think that antifreeze should be in contact with the heater core/hot water tank, so it should be run 'dry' in this case.
It does shut down gracefully.
