Changing a tire on TAB400 BDL
I have 3 full-size tires (235/75R15) for my 2020 TAB400 BDL and I just did my first tire rotation.  I had to remove the plastic fenders to change the tires,  I couldn't angle the tire out and past the hub otherwise.  Did I miss a trick here?
If not, all BDL owners need to have a square driver in your TAB toolkit to remove the 7 screws if you are ever going to change a flat tire.
  • falcon1970
    falcon1970 Member Posts: 758
    edited April 2020
    I am running 225/75R15's on my TAB400 and don't have a problem.  I wouldn't think 10mm would make a difference.  Try raising the tire higher off the ground.  That will allow the tire to drop lower and not have to angle out so much.
  • SweetlyHome
    SweetlyHome Member Posts: 336
    @rh555, we hope that you are not lifting the T@B by placing your jack the axle assembly. Search here on the forum for 400 tire change instructions.
  • greggill
    greggill Member Posts: 45
    I had the same problem. Had to take the fender off also. I was afraid of breaking it otherwise.
  • rh5555
    rh5555 Member Posts: 540
    @falcon1970, I thought the standard non-boondock tires are 205/75R15's which are 30mm narrower; that would make a lot of difference.  I was jacking on the frame in the approved spot, but my floor jack could only get the tire about 4" off the ground.  I probably wouldn't even get that using the car's scissor jack.
  • falcon1970
    @rh5555
    I replaced the standard tires with Goodyear Endurance tires.  The largest they come in is 225's.  In any case, 4' should be high enough.  However, the Goodyear tires have a regular tread rather than the aggressive off-road tread.  I wonder if that makes the difference.
  • Denny16
    Denny16 Member Posts: 5,430
    probably not, do you have the Boondock fender flavors or the standard TaB 400 flairs?
  • falcon1970
    I have the Boondock TAB.  I didn't know there was a difference between the two fenders.
  • Denny16
    edited November 2020
    Yes, looking at photos of 2020 Boondock TaB 400, the Boondock fender flair is thinner looking, covering less of the wheel’s side wall.
