Changing a tire on TAB400 BDL
I have 3 full-size tires (235/75R15) for my 2020 TAB400 BDL and I just did my first tire rotation. I had to remove the plastic fenders to change the tires, I couldn't angle the tire out and past the hub otherwise. Did I miss a trick here?
If not, all BDL owners need to have a square driver in your TAB toolkit to remove the 7 screws if you are ever going to change a flat tire.
I am running 225/75R15's on my TAB400 and don't have a problem. I wouldn't think 10mm would make a difference. Try raising the tire higher off the ground. That will allow the tire to drop lower and not have to angle out so much.0
@rh555, we hope that you are not lifting the T@B by placing your jack the axle assembly. Search here on the forum for 400 tire change instructions.Jupiter, Florida~T@B 400, with 2018 Toyota 4Runner
I had the same problem. Had to take the fender off also. I was afraid of breaking it otherwise.0
@falcon1970, I thought the standard non-boondock tires are 205/75R15's which are 30mm narrower; that would make a lot of difference. I was jacking on the frame in the approved spot, but my floor jack could only get the tire about 4" off the ground. I probably wouldn't even get that using the car's scissor jack.
Roger and Sue Hill | 2020 T@B400 Boondock (Cryst@bel) | 2022 Land Rover Defender 110 - P400 | San Juan Island, WA0 -
@rh5555
I replaced the standard tires with Goodyear Endurance tires. The largest they come in is 225's. In any case, 4' should be high enough. However, the Goodyear tires have a regular tread rather than the aggressive off-road tread. I wonder if that makes the difference.0 -
probably not, do you have the Boondock fender flavors or the standard TaB 400 flairs?
I have the Boondock TAB. I didn't know there was a difference between the two fenders.0
Yes, looking at photos of 2020 Boondock TaB 400, the Boondock fender flair is thinner looking, covering less of the wheel’s side wall.
Cheers2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.0
- 144 Events & News
- 923 Introductions
- 76 Teardrop Groups & Links
- 921 Tips & Tricks
