Installed battery monitor today. When I connected the head unit, it did not turn on. I did have a spark when connecting the negative lug. All other electrical devices seem to work.
Does it matter which side of the shunt goes to battery and which side goes to block? I may have that backwards too.
Don't know about your brand monitor. However on the cheaper (price/quality/operation) China one I have it does matter . . . wiring backwards (on mine) just causes the Discharge / Charging data to be backwards, does not cause any failure issues.
'18 320 S, pitched axle, 3020HE; PNW based TV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller Adventures: 56Nights: 379 Towing Miles 47,220
@MuttonChops so was I. Had the wires switched. Must have been due to working in the heat 🙄🙄. Seems to be working. Have one odd reading I need to figure out. Also need to figure out how to get the head unit out of set up mode
If you complete the set up 9m your smart phone, 5he head unit will eventually catch up. Assuming g you have a Bluetooth enabled device...
Head seems to have caught up. Thank you for the help. I am getting an alert about the midpoint voltage. I will use the battery a bit before I worry about it. May just be that the system is learning.
head unit not coming out of set up mode. Seems to be working otherwise
2020 T@B 400 BD Lite
I get that title . . . an I was trained as an Engineer.
