What wax to use to shine my 2005 T@B Dutchman??
  Hi ... what wax do i use to shine up my 2005 T@B?
Bob
2005 T@B Dutchman
2019 Tacoma
  • I use Meguires Wash and Wax on my Tab 320S, and on our cars. It’s simple, one step, with great results. Congratulations on your Dutchman!
  • Any good quality Marine/RV wax will work nicely.
  • CRETBO...Have you thought about Ceramic coating?
    Ceramic protectants provide a much higher durability than wax. They resist heat, UV rays, environmental contaminants & harsh detergents much better than wax. Plus, wax simply sits on the paint's surface, it does not create the chemical bond like we find with ceramic coatings.
  • Ceramic protectants??  Not heard of this?  Explain... sounds good!
    2005 T@B Dutchman
    2019 Tacoma
  • @CRETBO, as with everything, you can search on ceramic coating here on the forum for some discussions, and the web. Owning an RV is probably more fun if you luv product research.
  • Ceramic coatings..I put it on my car. it's been almost 2 years and the water just runs off like it's been heavily waxed. I bought it through Amazon Prime.
     https://drivedetailed.com/best-ceramic-coating-for-beginners/
    there are a lot out there. I just picked a cheaper...I mean less expensive one..got get whatever you are putting it on really clean first.
  • Denny16
    edited May 2020
    And a 1 gallon Ceramic coatings kit for an RV will cost you around $150
    I will stay with my $25 Marine Silicone wax/polish.  :D
  • ZEP Wet-Look Floor Polish, works great
    Here is a link to an earlier discussion about ceramic coatings. It might be worth reading some of the comments before you take the plunge.
    https://tab-rv.vanillacommunity.com/discussion/10604/ceramic-coating
    Generally any high quality automotive wax will suffice. Many folks swear by AstroShield...there are sooooo many choices.
  • Thanks for all the good input ... For this time, i'm going to use a car wash/wax and do some more research.  Thanks again for all the information.  Perfect
    2005 T@B Dutchman
    2019 Tacoma
  • "Generally any high quality automotive wax will suffice."
    yeah, I agree,,,I did put ceramic coating on my car..it was sort of a pain....
  • The Tab is a Fiberglas laminate, and Marine wax is formulated for fiberglass surfaces, and offers longer lasting protection than auto wax.
