Does anyone have one yet? Does having the bed pulled out interfere with the opening of fridge? Any other warnings/insights would be helpful. I’ll be special ordering one just trying to decide if there’s anyone’s experience they can share. Sometimes there’s 3 of us and sometimes it’s just me and the pup.
2021 T@B 400 Boondock White/White; TV: 2020 Honda Ridgeline
2015 T@B Sofitel Silver/Silver; TV: 2011 Honda PilotMaryland's Eastern Shore - Ravens, Crabs, Bohs & O's!
Traveling with Violet Bean, most of the time...
You can see the bed blocking the walk area to the fridge, and blocking some of the galley cabinets. Seems when using the galley, the bed needs to be changed to the
“single” position, closed up.
This is an interesting layout, that we considered before buying the standard TaB400.
We like the big closet in the standard layout, with the two-way fridge. But nuCamp may have gone to a two-way compressor fridge in the 2021 TaB400 for the larger fridge option (from what Princess RV was saying in a walk through video) replacing the three way (black door) previously used in 2020, which is a good move if this is the case. This becomes a nice option for those not needing the closet area, while retaining the more efficient two-way fridge.
As newer technology battery based systems are developed, I see not too far off, AC/DC systems completely replacing propane in RVs. I live in a rural area, where our home fuel choices started out wood fire based heat/hot water, to propane and diesel fuel, and now electrical systems with solar options are starting to replace all the traditional fuel methods,
Larger home type Alde systems can be very efficiently used with AC/DC solar systems, augmented by shore power. So the move away from fossil fuels has begun...
“But nuCamp has gone to a two-way compressor fridge in the 2021 TaB400 for the larger fridge option replacing the three way (black door) previously used in 2020, which is a good move. This becomes a nice option for those not needing the closet area, while retaining the more efficient two-way fridge.”
Hoping this configuration is possible:
Here’s the configuration I selected:
It should be a blank canvas for decorating! 😊
I’ll wait on the maxxair fan - for now. I’ll probably get done at dealer at delivery or some other less busy time.
Do post some photos when it arrives.
Did you order from Beckley's?
I picked up my 2021 T@B 400 Boondock from them yesterday, and they were great to work with.
And it's a really nice little'ish camper! Towed beautifully and easily - I had a 325 mile trip home so it had a good shake down trip.
Glad you were able to order the perfect new camper! Good luck with it all.
P.S. I think your white on white is going to look great. I probably wouldn't have ordered the new gray trim that the in-stock one that I bought had, but I actually like it a lot in person.
I did end up ordering from Miller’s Trailer in PA though. Beckleys was very busy and Millers a bit more responsive and has a good reputation as well. They’re about the same distance from me give or take a few miles. It should be delivered in August.
"And then try not to fill up the camper again lol"
That's going to be the hardest part!!
Thanks. Still shopping around.
Wrenaa said:
2019 320 Boondock Edge - Sold Jan 2022
If you want room for two people to watch TV from bed, you need the standard (non solo) version of the TaB400, the TV is mounted on the wall at the foot of the bed.
