Hi Tabbers
Last Sunday i gave a deposit 500$ on a 2020 TaB 400 BD lite...I was so excited but tonite after reading bad reviews about AC air8 ...I’m thinking to walk away from the deal tomorrow morning! They had a 2019 unit ....should I buy 2019 instead? Need help here!
Harold
A ringing endorsement...not exactly. You'll have to eval how important A/C is vs. the delta between the 19 and the 20.
Sleep on it...you'll make the call that works for you.
San Diego, CA
www.airbossone.com
2013 Tundra TRD 5.7L
Massachusetts
Like @xdr said, everyone's needs are different. Having said that, I stayed away from the 2020 T@B 400 specifically because of the issues a number of members reported with very poor performance of the Air 8.
I could of bought a 2020 model a few miles from my house, and chose to drive 650 miles round-trip to get a 2021 model with the coolcat.
While I have no first hand experience with the Air 8, I can tell you the 2021 (and I assume all former models with coolcat) works incredibly well.
I just couldn't see buying something that I know is going to need a factory update the day I get it on such an important (to me) component of the camper.
Good luck with what ever decision you make!!
Be aware though that a few 2019s reportedly have the Air8, so you’ll need to check, and those that have the Coolcat may have a much heavier tongue weight than the 2020 or 2021. If your tow vehicle has the bare minimum towing capacity of 5000 lbs, you may end up exceeding the usual tongue weight limit of 500 lbs once you’ve loaded a 2019 up for travel. So make sure your tow vehicle is up for that before buying.
I’d skip both and go with a 2021, which was redesigned to fix the tongue weight issue.
thanks everyone for your help!
There are a few steps you can take to help in the mean time.
Are all these steps a fix...no. Each are a band-aid but they can make a difference.
I share your thoughts and am hopeful Elwell and nuCamp will make it right. They do have that history.
San Diego, CA
www.airbossone.com
Concord, NC
