Hello Forum!
I haven't posted in a while, but am traveling in the TAB again and would like to clean the filter. The Danby is designed to slide the filter out to the right to clean it, but it is installed so close to the wall that I can't do that I don't think. Wondering if need to remove screws that hold front piece on and then slide it out? The screw on side next to the wall is also a little difficult to access, so before really getting into it, I thought I'd ask if there is an easier way? Any thoughts?
THANKS SO MUCH!
Northwestinatab
1 ·
2019 320 Boondock Edge - Sold Jan 2022
"Growing old is mandatory. Growing up is optional."
I bow to all of you that were brave enough to test the plastic screen's ductility...
Thanks so much for these helpful comments! Sorry it took a while -- I'm job hunting if you can believe it and so other things took priority for a while... Okay -- so I think I'll pull it out to clean it (using the left hand to brace technique), and then on a day when I have more time I'll pull the whole thing out and clean thoroughly, etc. YAY! Thanks to all of you!
Northwestintab
