Replacement T@B tail lights?
Hello... one of my LED tail lights is not working and it has been determined that the issue is the light itself, not in the wiring. The unit I have is a 4" round 18 diode stud mounted light. Is it possible to replace just the lens unit or does the whole stud mount unit need to be replaced? Also, it's been a challenge to find this exact unit. Does anyone have this part number/name/brand/seller information? Any help/suggestion is appreciated.
  • Verna
    Verna Member Posts: 6,876
    Contact a dealer, give them the year, model and VIN and they will order one from nüCamp for you and have it drop shipped to you. Missouri Teardrop is a good dealer who doesn’t mind doing this even if you didn’t buy the T@B from them.
  • ywibben
    ywibben Member Posts: 3
    Yes, I found that link as well. The problem is trying to find the same unit as is installed. I will call the recommended dealer. Thanks.
  • Bayliss
    Bayliss Member Posts: 1,534
  • N7SHG_Ham
    N7SHG_Ham Member Posts: 1,261
    What do you mean stud mount? Isn't that held in by the two screws on the red lens? Looks like you could reuse the lens and replace the led board? I am about 99.99% sure NuCamp just bought these off the shelf someplace. No part number or make on the current one? LED lights are pretty generic and most are common sizes.
    Look at Grote, TruckLite, etc. To see what they
    MuttonChops Member Posts: 2,085
    On my 2018 model year T@B 320 the LED tail light is a
    Kaper II L15-0021
    Amazon price:
    Kaper Web Site:
    Tail light part number found by removing plastic housing that tail light mounts into.
  • ywibben
    Awesome. That is it. Thank you so much.
  • AWlks
    AWlks Member Posts: 4
    Awesome. Thank you @MuttonChops!
