Replacement T@B tail lights?
ywibben
Member Posts: 3
Hello... one of my LED tail lights is not working and it has been determined that the issue is the light itself, not in the wiring. The unit I have is a 4" round 18 diode stud mounted light. Is it possible to replace just the lens unit or does the whole stud mount unit need to be replaced? Also, it's been a challenge to find this exact unit. Does anyone have this part number/name/brand/seller information? Any help/suggestion is appreciated.
I searched “tail light” and found this:
https://tab-rv.vanillacommunity.com/discussion/comment/134724#Comment_134724
Contact a dealer, give them the year, model and VIN and they will order one from nüCamp for you and have it drop shipped to you. Missouri Teardrop is a good dealer who doesn’t mind doing this even if you didn’t buy the T@B from them.Verna, Columbus, IN
Yes, I found that link as well. The problem is trying to find the same unit as is installed. I will call the recommended dealer. Thanks.
@ywibben, here is another possible helpful thread:
https://tab-rv.vanillacommunity.com/discussion/comment/125841#Comment_125841
Greg & Marlene (Tucson, AZ)1 -
What do you mean stud mount? Isn't that held in by the two screws on the red lens? Looks like you could reuse the lens and replace the led board? I am about 99.99% sure NuCamp just bought these off the shelf someplace. No part number or make on the current one? LED lights are pretty generic and most are common sizes.
Look at Grote, TruckLite, etc. To see what they2019 T@B 400 Boondock Lite1 -
@ywibben ;On my 2018 model year T@B 320 the LED tail light is a
Kaper II L15-0021
Amazon price:Kaper Web Site:Tail light part number found by removing plastic housing that tail light mounts into.
Adventures: 59 Nights: 411 Towing Miles 50,3502 -
Awesome. That is it. Thank you so much.0
Awesome. Thank you @MuttonChops!1
