I am in transition from a 2014 T@B 320 CSS Maxx to a 2020 T@B 320 CSS BDL. 2014 had a standard Frigidaire room air conditioner. 2020 has the Elwell Air8. I have read many threads on the Air8, as I was concerned before buying. Looks like most of the issues are occurring on the 400. As a side comment, I am thrilled with the 3 air vents in the 2020 - love the air circulation when the Air8 is running.
Given that I'm coming from an A/C unit that basically had on/off, high/low cool, high/low fan, I'm trying to understand if the Air8 has a configuration setting that allows the fan to be always on - not auto - AND cooling at the same time. Near as I can tell from working with it, it can only do Fan only Always on and Cooling to temp, etc., which switches compressor and fan off/on based upon set point. Also, of course, my manual diagram doesn't match the control panel. Manual has 2 snowflakes, control panel has snowflake and teardrop. Any experts out there willing to offer their experience? Thanks in advance!
Beth
Beth
Minnesota
Practicing to be a wanderer
2020 T@B 320 CSS Boondock Lite
2014 T@B 320 CSS M@xx2020 Jeep Wrangler Unlimited 8 speed automatic
2020 Jeep Grand Cherokee Limited V8
2018 Jeep Wrangler Unlimited Rubicon 6 speed manual
Concord, NC
Next project - read the Alde manual to see if that digital display can be dimmed ....
Minnesota
I havemt dug too deeply into the manual, yet, but I couldn't find anything about having to reset. I would love to be able to mod this to correct it. I plan on emailing Elwell tomorrow.
I am otherwise thrilled with the Air 8.
Minnesota
Minnesota
"Hi Stuart,
From my experience with the Air8, the dehumidification mode does not feel much different than the cooling/AC mode.
It will still blow cold air in the dehumidify mode, but it will be attempting to pull more moisture out of the air at the same time"
On another note, the Air 8 manual says the middle trunk (I believe) should be used for the longest run which would be the one above the control panel. Mine is not set up like that..not should how much of a difference it really makes, but I plan to swap mine at the unit becuase that is what the distributor recommends.
Happy TAB cooling....
Southern Maryland
