No, the battery monitor gives you the real state of charge, not just a reading of current voltage.b407driver said:Can you not get all the info you need from the smartphone app? If not, I may also install the monitor.
75/10, actually. At least that's what's in my October build.N7SHG_Ham said:Is nucamp using the Smart Solar mppt 75/15 now?
YES! They started using that mid 2019 builds.
Doh! I think I got pimped.Ninabean said:I just bought my Tab400 2019 but a December 2018 build. It has the 75/15 Smart Solar.
AirBoss said:@Denny16
@TNOutback
Curious how you thought the installation of the BMC712 went. Where did you locate the monitor? Much wood butchering required. Running wiring fairly straight-forward? Is it worth seeking professional installation?
I'm no electrician but I have a moderate level of knowledge in wiring 200amp electrical panels and installing fixtures in a home and barn some years past (at least it passed inspection!).
Thanks in advance.
Did a Google search on this and came up empty handed. If both apps are in "Victron Connect" does this become the network? It does seem like information is being shared between solar panel --> batteries. Anyway to know for sure? Thanks!TNOutback said:If you have both devices, be sure and set up a network between the two of them, so the solar controller is taking info from the battery monitor to fine-tune its charging profiles.
Thank you #TNOutback!TNOutback said:Networking the BMV-712 to the solar charge controller will allow the controller to sense voltage, current, and temperature from the BMV. This link from their help explains it:
https://www.victronenergy.com/live/victronconnect:ve-smart-networking
TNOutback said:If both BMV-712 and MPPT 75/15 Controller apps are in Victron Connect, you are wearing ruby slippers. To click the heals, follow the link above provided by TNOutback. Fast, easy and worthwhile!Networking the BMV-712 to the solar charge controller will allow the controller to sense voltage, current, and temperature from the BMV. This link from their help explains it:
