Keder rail?
julz61
Member Posts: 1
I am a newbie and thank you for the add! I would like to have an awning made from Marti’s and she needs to know the type of keder rail I have. It’s a 2014 Pleasant Valley Teardrop and this is what the keder rail looks like. This black flexible tube strip comes out. Is it suppose to? Will I have to remove it and slide it over the awning edge then slide it all into the groove? Is there a site Or video that I can refer to for this?
Edited for photo size.
Welcome julz61. The black strip is decorative and gets removed to use the keder rail.8.5mm (or 5/16") keder cord works well--it has a flap which gets sewn onto whatever it is you ate trying to attach to the rail.The gap is the rail is 1/4". The width of the opening (where you slide the cord in) and the inside channel is 3/8" - 7/16" at best--it's hard to get the calipers in there for an exact measurement.2015 T@B Max S (320)
The black plastic insert can be removed and discarded. It is just a filler. Someone posted the size of keder rope required for our rails. I will try to locate it.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
https://tab-rv.vanillacommunity.com/discussion/comment/141558#Comment_141558
Keder rail size on this thread.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
- 916 Introductions
- 72 Teardrop Groups & Links
