Keyless entry lock for new 2021 tab 400
Hi new NuCamp friends!  We brought home our new 2021 Tab 400 BD about 3 weeks ago and I want to install a keyless entry lock on the door, does anyone know of one that will fit this model?  I'm having trouble figuring out which kind will fit.  I'm having so much fun making it my new full time home.  I will be traveling solo and plan to be on the road by Sept 1, I'm so excited!  Thanks for suggestions.
  • VictoriaP
    VictoriaP Member Posts: 1,496
    edited July 2020
    There are currently no aftermarket replacement lock options (keyless or regular) for the Tab 400 door, or the 2020-2021 320 door.
  • Blazer
    Blazer Member Posts: 5
    Thank you!
  • Denny16
    Denny16 Member Posts: 5,430
    Also, the TaB 400 key is a unique security type key lock, with many key variations, so some one else’s TaB400 key is not likely to fit your TaB400.
  • Blazer
    Good to know, thanks!
  • Denny16
    edited September 2020
    @Blazer, you’re welcome.  Whe we go our 2018 TaB400, I had the same thought of changing out the locks, and our local RV Trailer center, checked into it and found out they were already security style locks, and we left it at that.  Our nüCamp dealer also confirmed this.  So the OEM lock is good as is.
  • TRob
    TRob Member Posts: 54
    Hopefully there will be an aftermarket keyless entry lock available at some point. The main thing I like about them is you can still get in to your camper even if you lose your key! :)
    Troy / 2020 Jeep Gladiator Rubicon / 2021 Tab 400 BD / Sarasota, FL
  • Denny16
    You might find some in Europe, as the complete door, frame, and latch all come directly from Europe to nüCamp, from what I understand.  So not likely you will find anything on this side of the pond, as not that many TaB 400 have been sold.
  • krsmes
    krsmes Member Posts: 88
    I know this conversation is a few years old but I’m curious if anyone has found keyless door lock options for the T@B 400
  • SLJ
    SLJ Member Posts: 669
    Still nothing for the newer 400s or the 320s with the newer style door.
    2021 T@B 320 S Boondock
    2025 KZ Sportsmen 130RD
    2025 Ford Ranger
    The Finger Lakes of New York
