Keyless entry lock for new 2021 tab 400
Blazer
Member Posts: 5
Hi new NuCamp friends! We brought home our new 2021 Tab 400 BD about 3 weeks ago and I want to install a keyless entry lock on the door, does anyone know of one that will fit this model? I'm having trouble figuring out which kind will fit. I'm having so much fun making it my new full time home. I will be traveling solo and plan to be on the road by Sept 1, I'm so excited! Thanks for suggestions.
There are currently no aftermarket replacement lock options (keyless or regular) for the Tab 400 door, or the 2020-2021 320 door.2019 320s BD Lite, white with blue (“Haven”)
Pacific NW -
Thank you!
Also, the TaB 400 key is a unique security type key lock, with many key variations, so some one else’s TaB400 key is not likely to fit your TaB400.
Good to know, thanks!
@Blazer, you’re welcome. Whe we go our 2018 TaB400, I had the same thought of changing out the locks, and our local RV Trailer center, checked into it and found out they were already security style locks, and we left it at that. Our nüCamp dealer also confirmed this. So the OEM lock is good as is.
Hopefully there will be an aftermarket keyless entry lock available at some point. The main thing I like about them is you can still get in to your camper even if you lose your key!
Troy / 2020 Jeep Gladiator Rubicon / 2021 Tab 400 BD / Sarasota, FL -
You might find some in Europe, as the complete door, frame, and latch all come directly from Europe to nüCamp, from what I understand. So not likely you will find anything on this side of the pond, as not that many TaB 400 have been sold.
I know this conversation is a few years old but I’m curious if anyone has found keyless door lock options for the T@B 400
Still nothing for the newer 400s or the 320s with the newer style door.krsmes said:I know this conversation is a few years old but I’m curious if anyone has found keyless door lock options for the T@B 4002021 T@B 320 S Boondock
2025 KZ Sportsmen 130RD
2025 Ford Ranger
The Finger Lakes of New York
- 916 Introductions
- 72 Teardrop Groups & Links
