New Battery ( 24C form Costco) in a 2017 T@b S Max but the Battery will not power the trailer
My old Centennial battery had dies, so I purchase a new one form Costco but it won't power the trailer. If I plug the Trailer into an outlet the power is working. I'm not sure if I need to replace any fuses. Please help
  • Denny16
    Denny16 Posts: 5,430
    Has the new battery been charged?  What trailer do you have?
    pthomas745 Posts: 4,645
    This is Fuses for Newbies.  Check that fuse next to the battery, the very first one in this file:
    While you are there looking at the fuse, look for the Battery Disconnect Switch. It looks like this. This switch must look like this ( "On") to bring battery power to the trailer. to
    Welcome to the Forums!
  • Yes I did switch it on but still not powering. Thank you  for the informations I will check the fuse in the Battery. Greatly appreciate all the help.
  • Yes the nwe battery is fully charge, I brought the old battery to Costco and they gave me the Costco brand and told me it’s the same kind with the centenial one just different brand
  • Michigan_Mike
    Michigan_Mike Posts: 2,858
    So did the new replacement battery solve your problem?
    If you had your battery out and then back in.....send us a picture (if you can) of how the wiring of the battery looks now.  The Tab gets a bit confusing......
    ScottG Posts: 5,688
    In addition to the fuse at the battery itself, there are two fuses in the converter that also need to be intact for the battery to provide power to the trailer. One is labelled "battery charger" and the other "reverse polarity protection" (or something similar). On mine they are the bottom two fuses in the converter's 12V fuse panel.
  • Thank you
  • @pthomas745... Thank you for info regarding  the fuses. It was the fuse  for the battery wires that was burnt. I just replaced the 30 amp fuse and now its working. You save me $$$ for not getting it service. 🤗🤗🤗
    Good!  Thank all the brilliant people here who worked out "Fuses For Newbies" for everyone!
