I have a Toyota Tundra TV. 2010. Also a Tab 400 2019.
Since i had the truck, it has a common issue where on roads that have rapid horizontal undulations, the truck magnifies them to where it is annoying. Some mods were made to the model to reduce this. Keeping the tires rotated and balanced well helps greatly.
On my long trips down South, there are stretches of I81 where the roads gave these lateral cracks close together. When towing this sets up a resonance and my Tundra/Tab have this vertical see- sawing. It is worse above 60mph even at 40mph its annoying. Some air in my airbags helps, but too much makes it worse. (I usually run 20psi, but 15 seems optimum when bouncing). I just changed the Bilstein rear shocks, which were not bad, just in case, but no difference. Also tried the rubber mounted tow hitch ball, which i think makes it worse.
Anyone know of anything which fits between the TV and Tab to damp this?
In England I had a damper which was a wide spring bar with a friction joint which was bolted to the TV and the bar rested on a u channel on the Trailer. The friction joint (horizontal) damped sideways swerving and the spring bar resisted the vertical flexing motion.
I just would like the vertical damping.
Haven't seen anything. An equalising hitch would be overkill i think.
A WDH might actually be the exact thing you need for this. While it may seem on paper like overkill for your rig, many people report a smoother more well mannered tow after adding one to their rigs.
The Fastway E2 seems like the one that best fits our T@Bs:
https://tab-rv.vanillacommunity.com/discussion/8518/fastway-e2-wdh-installation
Another item you might want to look at are the Gen-Y Torsion hitches. I'm using this one:
https://genyhitch.com/product/the-glyder-torsion-flex-hitch/
It's a properly designed (and built) version of the rubber mounted hitch ball you may have already tried. A bit spendy, but truly built to tank-like standards. But for what you're describing, my bet is a WDH would help you out more than the torsion hitch, although the torsion hitch is specifically damping/isolating just the vertical motion you mention.
I had a similar issue going over rough roads, lots of them where I live, and with 400+ lols balanced on the rear of the tuck, it would bounce up and down some. I changed out my rear springs and shocks for the Jeep MaxTow progressive springs, that have more resistance when compressed, and will better control a up and down bouncing motion when loaded down.
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePo4; Solar: Renogy 100Ah Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
Like @Denny16, I swapped out all four shocks for Bilstein shocks designed for heavy-duty SUV's and replaced rear coils with Moogs. Made a world of difference, but then they were due to be replaced anyway.
I have to say a WDH and/or Torsion hitch are far less expensive and likely will go a long way to solve your issue. May go the Torsion hitch route myself. No much in the way of porposing anymore but it's noticeable from time to time.
Good luck...keep us posted on your choice.
San Diego, CA
www.airbossone.com
Because it creates more of a unified motion between TV and Trailer...possibly damping the porpoising...whereas the Gen-Y Glyder I *think* helps more with smoothing out the abrupt bouncing like a pothole or action that affects each axle separately.
I hope you find a solution that works great for you.
I've been so happy with my set up in regards to it's towing comfort. I have to believe with your truck's capability there is a setup that makes the T@B virtually disappear regarding towing it.
San Diego, CA
www.airbossone.com
Is it too late for me to open an RV sales and service center? Its like printing money right now.
San Diego, CA
www.airbossone.com
2013 Tundra TRD 5.7L
Massachusetts
2015 Nissan Frontier SV, 4WD Crew Cab
Cottage Grove, MN
Massachusetts
When I switched from the 4runner I kept my Fastway e2 WDH and adjusted it to fit the Tundra. I also use hitch tightener ubolt thing to prevent the hitch from wobbling around in the receiver. To be honest I've only done a couple hundred miles so far with the Tundra but don't think I've experienced what you're describing. Maybe the WDH is preventing that?
