Circuit breaker/fuse panel fan operation
Kentsb
Member Posts: 67
When connected to shore power does the cooling fan run continiously?
52 nights
If it is charging the battery, yes, the converter fan runs.
Towed by 2014 Touareg TDi -
I would think after several hours the battery would be fully charged and the fan would shut off.
52 nights -
Not necessarily, depends on how far discharged the battery was.
The WFCO Power Center on-line theory of operation document says . . .
Automatic Cooling Fan: The microprocessor in the converter monitors the current drawn
by appliances and battery and increases the fan speed as current draw increases. This cools
the converter components as required by the load.
So if your Fan is on all-the-time the converter is drawing high current or has an internal failure.'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Adventures: 58 Nights: 405 Towing Miles 50,180 -
@MuttonChops - While on shorepower, if there are a lot of DC appliances running (lights, fan, frig, etc) it sounds like It will run the fan more as well. Is this correct?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
I know batteries vary for many reasons, but it seemed like it took more than six hours to charge the battery and the fan to shut off. All that was running was the frig.
52 nights -
How depleted was the battery?Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
Sharon, to answer your first question, yes, the higher the load on the power converter from charging and/or other 12 volt devices being used, the fan will come on according the the load to keep it cool.
Kentsb said:I know batteries vary for many reasons, but it seemed like it took more than six hours to charge the battery and the fan to shut off. All that was running was the frig.I do not know what type/style Fridge in a '21 CS-S.
That said; it is not unreasonable for the converter to have a high enough current demand while charging a "1/3" low battery and running Fridge if on 12-Volts to require fan cooling.Remember: For lead-acid battery useful capacity is only 1/2 of
rated capacity so a 1/3 low battery is indeed low.'18 320 S, pitched axle, 3020HE; PNW basedTV: '17 Colorado V6 Z71 4x4, Tow Package, GM Brake Controller
Also, the converter can take longer to charge a battery than solar or a dedicated charger. @Kentsb - effectively, the converter ends up splitting the current between the appliances and the battery, so it takes longer. It’s a good idea to get a better battery monitor than the KIB.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio
A good battery monitor is the Victron Smart Shunt or the Victron 715 wHitch includes a monitor display.Cheere2018 TaB400 Custom Boondock, Jeep Gladiator truck, Northern California Coast.
The "2way" fridge in the clamshell is really wired to run on DC power, so when the trailer is connected to shorepower the converter fan generally kicks on when the fridge compressor is running. I think that there's a way to truly run the fridge on 110 power, but I think that it involves getting another power cord for the fridge and wiring an outlet back there for the fridge.San Francisco Bay Area
My 2-way on my 07 CS only has a 12V connection. So it is either running off the converter on shore, or running off the battery in transit (with a charge line)Marceline said:The "2way" fridge in the clamshell is really wired to run on DC power, so when the trailer is connected to shorepower the converter fan generally kicks on when the fridge compressor is running. I think that there's a way to truly run the fridge on 110 power, but I think that it involves getting another power cord for the fridge and wiring an outlet back there for the fridge.
Carol
MOUSE-KE-T@B
2022 nuCamp T@B 320 CS-S
Harvest, AL -
@Kentsb, and others, just to add to this discussion, I just finished watching a WFCO training video regarding operation and troubleshooting of the power center/converter (link to video included below.) At around 15:45 on the video, the presenter explains that while the fan on the WFCO cools the 12V circuit board, it is load based, not temperature based. Therefore, the fan will turn on, and remain running, as long as the converter is drawing a certain 12V load threshold. They don't say what the load threshold is, but presumably it is pretty low. Thus, the fan will likely kick on, and remain on, whenever you are running the water pump, turning on lights, the radio, etc. If the power draw (i.e., load) drops below the pre-determined threshold, the fan will turn off. Also, I learned that even without a load, when you first plug in the trailer 120 VAC power, the fan will briefly turn on, then off (due to charging of the circuit board capacitors.)
https://www.youtube.com/watch?v=t_Qyur-fsAw&feature=emb_rel_end
2019 T@B 320 S Boondock Lite; 2025 Toyota Tundra CrewMax 4x4
Greg & Marlene (Tucson, AZ) -
Thanks, @Bayliss. That explains why my converter fan didn’t run (that I heard) the one night I was plugged into 110V after being on solar power since early December, which was 8 months. I was using very little power, even though on shore power, since I was so used to boondocking and conserving power.Verna, Columbus, IN
- 916 Introductions
- 72 Teardrop Groups & Links
