One of the real disappointments was the table in our 2013 model S.
Heavy, hard to fold up, and when we slept on the bed it moved, was not stable.
I removed it and replaced it with a wood table. I bought the birch plywood from Lowe's, used Poly-seal to finish it, and placed support rails around the edges of the opening, and a strengthening rib across the table.
The base, post, etc was a quick $25 Amazon. I did drill the floor ( after checking for wires, pipes, etc.) for the base, as i wanted it recessed.
walter
![Image: https://us.v-cdn.net/5021717/uploads/editor/wf/fntimdk1a02f.jpg](https://us.v-cdn.net/5021717/uploads/editor/wf/fntimdk1a02f.jpg)
![Image: https://us.v-cdn.net/5021717/uploads/editor/gn/n7jcdyhovbsm.jpg](https://us.v-cdn.net/5021717/uploads/editor/gn/n7jcdyhovbsm.jpg)
![Image: https://us.v-cdn.net/5021717/uploads/editor/0f/rguvngzzs5mx.jpg](https://us.v-cdn.net/5021717/uploads/editor/0f/rguvngzzs5mx.jpg)
![Image: https://us.v-cdn.net/5021717/uploads/editor/ru/bwgrdf5zrqq6.jpg](https://us.v-cdn.net/5021717/uploads/editor/ru/bwgrdf5zrqq6.jpg)
the hole goes through, i think its a 3" hole (used a hole saw in my drill)
I sealed it with caulking, then screwed it with wood screws.
i found the floor is a sandwich ply of plywood, foam insulation, a black synthetic fabric on bottom, and the linoleum floor on top.
If you don't want to drill a hole you can use the same fitting that is on the bottom of the table.
'15 T@B Max CS
Augusta, Maine
Thanks!
2015 T@B-L "Silver Dr@ggin" towed by 2015 Kia Sorento V6 "Don Poulan"
