Ok, so I purchased the Champion 2000 watt generator for my occasional Boondocking outings in the summer. I tried it out today, and it seems that it will not take the starting amperage of the Air8z. I thought I had enough, I guess I was wrong.
what are my options?
2020 T@B 400 BD Lite
0 ·
San Diego, CA
www.airbossone.com
I don't have the breadth of knowledge with 400s to be aware of an Easy Start type capacitor unit that would help your situation. That leaves two paths that come to mind;
* Buy a second 2000W champion and a parallel link unit. This should provide you with the same 30Amp power you get from a campground pedestal (Run that microwave, recharge the battery AND run the AC).
*Sell your 2000W unit and go bigger (Get it listed before the next big storm rolls up the coast and it may sell quick when the meteorologists go in overtime mode on the local news).
Best of luck with the journey...
2019 320 Boondock Edge - Sold Jan 2022
And just as I posted this, @CrabTab mentions the easy start capacitor as well. For the benefit of those of us who are considering a genset, please share what you did to investigate and how you came to the decision that you did.
Cheers and good luck!
San Diego, CA
www.airbossone.com
before I picked the champion; I looked on this site, reviewed the running load of the Air8; capacity of various genders including the Champion; after settling on the champion, called champion to confirm.
I presume the Air 8 runs as normal under shore power, correct? Maybe I missed that above. Not a fuse issue, correct?
San Diego, CA
www.airbossone.com
I think my options are:
1) check to make sure Air8 is operating properly
2) Check to make sure generator is operating properly
Depending on 1 and 2:
3) sell and replace generator with a larger model; or
4) by a second generator of the same size and gang them.
According to the manual, the Air* starting current is 15A for less than 1sec. The champion has a 20A "circuit breaker".
Not sure how to test to see if it is in fact a 15A start up surge, or that the "fuse" or "circuit breaker" on the generator is functioning properly. Regardless, the Champion should handle the Air*.
BTW, not sure it matters (haven't investigated) but which Champion do you have? Looks like there a several different models at that rating.
If you're at home, ensure the genset is running properly and then try plugging in something that draws 15-20 amps. A few items you may have around would be a hair dryer (10amps), an oil-filled radiator (13amps), a toaster (9amps), a vacuum (7-9amps), etc. Those are averages but you see where I'm going.
Start the genset. Turn off "Eco" mode. Plug in some combitnation of the above items or similar (switched on) into a heavy-duty extension cord (not the little white one under the couch!), then plug the extension cord into the genset. With those items in the "on" position they'll approximate something akin to 15-18amp start up draw. You could plug them in separately as well, though it does seem like the intial amp draw at start up may be the issue with the genset.
All that said, in looking at the Champion specs on line as I type this, the 120V outlets indicate "Max 14.2Amps." I assume (dangerous!) that this would hold true for the other Champion 2000W models. That would not seem to bode well for inital amp draw of 15amps of the Air 8. The marketing narrative of the Champion also indicates it's for "Power items around the RV like lights or TV or provide backup power for a few basics like lights, microwave, TV, modem/router or phone charger. This unit is not recommended for emergency home backup for air conditioners, stoves, furnaces or sump pumps."
On the surface, it would seem the Champion may not have the horsepower to crank the Air 8 over. Have you tried putting the Air 8 in fan mode only at start up, then selecting the A/C mode?
I appreciate all the input here from you and others. I'm in the market for a genset and have narrowed the field to four or five. This thread may have narrowed that field a bit...
San Diego, CA
www.airbossone.com
The outlets on my WEN 2250 are labeled as 20 amp (NEMA 5-20R), but elsewhere the literature says they are 15A receptacles. Whichever it is, the genset has no problem with the Air8 startup.
Yep...my guess as well. Thought perhaps using a few household appliances (either in bulk start or in sequence) might help him determine that. Just think the Champ isn't quite there, unfortunately.
Be interested to see what @NoVaGuy determines and how it's resolved.
San Diego, CA
www.airbossone.com
Speaking of MicroAir, that might be one way for the OP to use the Champion, that would be a $300 cost plus labor. I am thinking of one on my CoolCat as even the Honda chokes for a second when AC compressor starts. They definitely make an easier start, even on shore power.
Is this the generator you picked up from Cabela's?
We have this one (purchased with club points). It handles the punky needs of the AC in the 320.
Just for fun I tested it with some power tools when I first received it last year. It did operate my 12" Dewalt miter saw (about a 13 Amp draw). It would not start my Porter Cable twin tank air compressor. Can't readily find a spec on the compressor. It routinely runs on 15Amp circuits though.
An additional thought... What gauge wire are you running to the trailer? The 30Amp with an adapter for the generator receptacle?
close. I purchased the duel fuel version. According to the literature, it should handle 20A. I am using a 30A cable with adapter
Were you testing on propane or gas. Propane offers reduce output as mentioned above.
San Diego, CA
www.airbossone.com
@rh5555 the generator needed to be reset. It ran, but no output
