Permanent 200 watt Flexible Solar Install
@dsatwork, so nice to hear from a member of the family after such a long time! Stay in touch.2017 t@b sofitel(Dr@gonsFly)TV 2015 Silverado 2500hd(Behemoth). Wyandotte, Michigan.
Draco dormiens numquam titilandus.0 -
So when I'm towing, won't batteries be charging via vehicle (7-pin), as well as rooftop solar? So maybe the math is missing that part of the equation?
Most vehicles nowadays barely trickle charge your battery due to smart alternators and inadequate gauge wiring running from alternator/vehicle battery out to the trailer. To get an adequate charge from your tow vehicle, you’ll likely need to add a DC-DC charger into your setup.A_boondock_owner said:So when I'm towing, won't batteries be charging via vehicle (7-pin), as well as rooftop solar? So maybe the math is missing that part of the equation?2019 320s BD Lite, white with blue (“Haven”)
Pacific NW0
