A/C box
LARKLARK Member Posts: 146
edited September 2016 in Air Conditioning & Refrigeration
Has anyone noticed the air conditioner box is not insulated and has gaps at the opening? I believe I am going to install thermal and acoustic insulation silver sheets to provide some insulation.
M@rk and Donn@ : 2015 T@B S Max, Silver/Black, 2008 Toyota Beef Taco DC
    jdargisjdargis Member Posts: 305
    I would be concerned you might create the airflow problem, others are having with their condenser on their air conditioners.
    Air flow is the problem, that is why I'm in there. This is the beginning of my alteration to correct that problem. While I have it opened up I noticed the box is without any insulation leading to the inside walls of the box and that there are gaps when you remove the face trim. I have removed the a/c to place not only one fan to remove the heat through the top vent but another one bringing in fresh air next to the compressor. I will document on another post. Just wondering if anyone noticed the lack of insulation.
    Definitely post some pics - especially of the compressor fan hookup.
    I definetly notice a draft coming in around the AC when I have a good wind so sealed the gaps between the the AC unit and the frame inside.
    RadRad Member Posts: 516
    Hey, new Mod, did ya consider the outside snap on cover I guess you can get from the factory now as an after market item?
    My Silver Shadow definitely has some drafts coming around it when the wind hits it just right, so I'm interested in seeing the pictures, too.  I sure noticed it while wintering in the SS in the Southwest--the nights tend to get a bit cool and the winds in Arizona tend to just appear without warning.
    Rad - I'll have to check that out - Being out-n-about with limited tools, some foam packing material strips inserted was a quick-n-dirty solution ... Worked to seal the draft above the fridge too.
    Rad,
    Have you seen a listing on the Teardrop shop for the after market, snap on air conditioner cover for the wall mounted AC.  Which category is it listed in?
    Jeff
    jdargis said:
    Rad,
    Jeff
    No, I was told to call the factory, mmmmm, I think it was the factory and not the shop.
    The factory and the Teardrop Shop are in the same building.  The supplies are stored in the factory.
    Well, there ya go, I nailed the answer.......in a way B)
    Your lucky day Rad - Better buy a lottery ticket ;-)
    leenscottflleenscottfl Member Posts: 254
    Too late for lottery ticket.  Already used up his luck on something more important.
    jschemeljschemel Member Posts: 79
    To order the snap on AC cover call Elise at the factory 330-852-4811
    M-F 5;30-3:30 EST. Ours was $24.22 plus shiping and came with snaps you install on the frame.
    Jaynie and Larry - Palo Alto, CA - 2015 T@B CS-S - Expedition EL - Nights spent in "T@b Spirit of Holly" 97
    (9/22/19/
    Remember, the factory is closed all this week for the Forth of July.
    KathKath Member Posts: 8
    Does anybody have a link to the cover that is available from the factory? I'm at a loss with the search function. THANK YOU!
    KEEP THE MAGIC ALIVE!
    2015 T@B M@X S. . . he, she will name itself on the next trip. . .
    Which cover are you looking for?
    (9/22/19/
    For the air conditioner vent? We called Elise at the factory and she sent it out to us.
    (9/22/19/
    AldebaranJillAldebaranJill Member Posts: 452
    Could you post a picture of this Snap On AC Cover?
    Seattle, WA
    Thank you! Will order mine on Monday.
    Seattle, WA
    You can also make an AC cover - pretty easy. Search and you'll probably find ones both @sable and I have made. Sables attaches with velcro, mine with magnets.
    A question about the cover, I assume it's not insulated at all. Has anyone developed an AC cover that has insulation?
    Seattle, WA
    I presume insulated for winter use - if so, I'd probably just take the vent cover off and stuff some insulation in there and put the cover back on. You could also make a cover like @sabel did but using foam insulation board.
    edited October 2016
    I just use the factory purchased external (snap-on) cover and insulate the front seams at the front of my AC unit inside the trailer.
    Mike - Found with my external AC cover I no longer had to insulate the seam around the inside. The gaps around the fridge are another matter - the gap around the fridge lets more wind in then the AC so filled that gap.
    edited October 2016
    In looking at your cover photos, I am now wondering if my external grill dimensions are the same as yours (now that I know my AC electrical issue may have been due to a early version of T@Bs offering AC). My dimensions are 25 3/8 by 9 1/2, is this "normal"? It looks much longer than @Verna
    Seattle, WA
    Tabaz Tabaz Member Posts: 2,358
    Your's is a different size.  Mine is 22" wide x 10" tall (four screws).
    2016 Outback 320 with a 2010 Ford Expedition,
    Tell Elsie what dimensions and she can have the correct size made.
    edited November 2016
    Since my 2013 T@B has a different sized AC vent grille, and since most of my camping is in cool weather, and after reading many of you have had your AC covers blown off during travel, I decided to make my own.
    I had my water heater cover get blown off once in Wyoming during a severe windstorm. Therefore I wanted to make sure my AC cover, which would be on for most of the year, stayed put. I also wanted to be able to remove it without any tools. Yes, 8 screws is probably excessive, but that's what engineers do best :-)
    Here's the first version:
    The recipe:
    1. 1/4" plywood, painted black, coated with urethane
    2. auto/marine window seal glued to inside of cover
    3. wing screws (10-32), 3/4" long
    4. large washers
    5. drilled, then tapped holes in the metal grille face (to same threads as wing screws, 10-32)
    I wanted to try wood first, since it was easiest for me to obtain and work with, but aluminum or plastic would be a nice version 2, if the wood ends up rotting. But there's no way it's blowing off!
    Seattle, WA
    AldebaranJill, Looks nice, good touch with the wing nuts. Curiosity question: Has anyone tried tinted Plexiglas tinted to match the window, with kind of the same type attachment with the wing nuts and seal?
