A/C box
LARK
LARK Member Posts: 146
edited September 2016 in Air Conditioning & Refrigeration
Has anyone noticed the air conditioner box is not insulated and has gaps at the opening? I believe I am going to install thermal and acoustic insulation silver sheets to provide some insulation.
M@rk and Donn@ : 2015 T@B S Max, Silver/Black, 2008 Toyota Beef Taco DC
  • jdargis
    jdargis Member Posts: 305
    I would be concerned you might create the airflow problem, others are having with their condenser on their air conditioners.
  • LARK
    Air flow is the problem, that is why I'm in there. This is the beginning of my alteration to correct that problem. While I have it opened up I noticed the box is without any insulation leading to the inside walls of the box and that there are gaps when you remove the face trim. I have removed the a/c to place not only one fan to remove the heat through the top vent but another one bringing in fresh air next to the compressor. I will document on another post. Just wondering if anyone noticed the lack of insulation.
  • Nomad
    Nomad Member Posts: 7,209
    Definitely post some pics - especially of the compressor fan hookup.
    I definetly notice a draft coming in around the AC when I have a good wind so sealed the gaps between the the AC unit and the frame inside.
  • Rad
    Rad Member Posts: 516
    Hey, new Mod, did ya consider the outside snap on cover I guess you can get from the factory now as an after market item?
  • Verna
    Verna Member Posts: 6,876
    My Silver Shadow definitely has some drafts coming around it when the wind hits it just right, so I'm interested in seeing the pictures, too.  I sure noticed it while wintering in the SS in the Southwest--the nights tend to get a bit cool and the winds in Arizona tend to just appear without warning.
  • Nomad
    Rad - I'll have to check that out - Being out-n-about with limited tools, some foam packing material strips inserted was a quick-n-dirty solution ... Worked to seal the draft above the fridge too.
  • jdargis
    Rad,
    Have you seen a listing on the Teardrop shop for the after market, snap on air conditioner cover for the wall mounted AC.  Which category is it listed in?
    Jeff
  • Rad
    jdargis said:
    Rad,
    Jeff
    No, I was told to call the factory, mmmmm, I think it was the factory and not the shop.
  • Verna
    The factory and the Teardrop Shop are in the same building.  The supplies are stored in the factory.
  • Rad
    Well, there ya go, I nailed the answer.......in a way B)
  • Nomad
    Your lucky day Rad - Better buy a lottery ticket ;-)
  • leenscottfl
    leenscottfl Member Posts: 254
    Too late for lottery ticket.  Already used up his luck on something more important.
  • jschemel
    jschemel Member Posts: 80
    To order the snap on AC cover call Elise at the factory 330-852-4811
    M-F 5;30-3:30 EST. Ours was $24.22 plus shiping and came with snaps you install on the frame.
    Jaynie and Larry - Palo Alto, CA - 2015 T@B CS-S - Expedition EL - Nights spent in "T@b Spirit of Holly" 97
    (9/22/19/
  • Nomad
    Remember, the factory is closed all this week for the Forth of July.
  • Kath
    Kath Member Posts: 8
    Does anybody have a link to the cover that is available from the factory? I'm at a loss with the search function. THANK YOU!
    KEEP THE MAGIC ALIVE!
    2015 T@B M@X S. . . he, she will name itself on the next trip. . .
  • jschemel
    Which cover are you looking for?
    (9/22/19/
  • jschemel
    For the air conditioner vent? We called Elise at the factory and she sent it out to us.
    (9/22/19/
  • AldebaranJill
    AldebaranJill Member Posts: 478
    Could you post a picture of this Snap On AC Cover?
  • Verna
  • AldebaranJill
    Thank you! Will order mine on Monday.
  • Nomad
    You can also make an AC cover - pretty easy. Search and you'll probably find ones both @sable and I have made. Sables attaches with velcro, mine with magnets.
  • AldebaranJill
    A question about the cover, I assume it's not insulated at all. Has anyone developed an AC cover that has insulation?
  • Nomad
    I presume insulated for winter use - if so, I'd probably just take the vent cover off and stuff some insulation in there and put the cover back on. You could also make a cover like @sabel did but using foam insulation board.
  • Michigan_Mike
    edited October 2016
    I just use the factory purchased external (snap-on) cover and insulate the front seams at the front of my AC unit inside the trailer.
  • Nomad
    Mike - Found with my external AC cover I no longer had to insulate the seam around the inside. The gaps around the fridge are another matter - the gap around the fridge lets more wind in then the AC so filled that gap.
  • AldebaranJill
    edited October 2016
    In looking at your cover photos, I am now wondering if my external grill dimensions are the same as yours (now that I know my AC electrical issue may have been due to a early version of T@Bs offering AC). My dimensions are 25 3/8 by 9 1/2, is this "normal"? It looks much longer than @Verna
  • Tabaz
    Tabaz Member Posts: 2,421
    Your's is a different size.  Mine is 22" wide x 10" tall (four screws).
  • Verna
    Tell Elsie what dimensions and she can have the correct size made.
  • AldebaranJill
    edited November 2016
    Since my 2013 T@B has a different sized AC vent grille, and since most of my camping is in cool weather, and after reading many of you have had your AC covers blown off during travel, I decided to make my own.
    I had my water heater cover get blown off once in Wyoming during a severe windstorm. Therefore I wanted to make sure my AC cover, which would be on for most of the year, stayed put. I also wanted to be able to remove it without any tools. Yes, 8 screws is probably excessive, but that's what engineers do best :-)
    Here's the first version:
    The recipe:
    1. 1/4" plywood, painted black, coated with urethane
    2. auto/marine window seal glued to inside of cover
    3. wing screws (10-32), 3/4" long
    4. large washers
    5. drilled, then tapped holes in the metal grille face (to same threads as wing screws, 10-32)
    I wanted to try wood first, since it was easiest for me to obtain and work with, but aluminum or plastic would be a nice version 2, if the wood ends up rotting. But there's no way it's blowing off!
  • ericnliz
    ericnliz Member Posts: 4,437
    AldebaranJill, Looks nice, good touch with the wing nuts. Curiosity question: Has anyone tried tinted Plexiglas tinted to match the window, with kind of the same type attachment with the wing nuts and seal?
