BATTEN DOWN THE HATCHES
Tampakayaker
Member Posts: 558
So we live in FL and like quite a few other states, get to experience hurricanes. We have a 320 that is parked in our driveway, no garage, just protected with a cover.
This is our first year with the T@B and hurricanes.
Looking for advice from others on the best way to ride out a storm with the trailer in our driveway.
There are no large trees nearby that could fall on it. Of course debris, branches could become airborne.
Would I be better off just leaving the trailer as is (of course removing the cover) or hooking it up to my RAM for added weight?
I know we could hitch up and try to avoid the storm by driving away, but the last time a storm got near Tampa all of the major roads became parking lots, and the storm veered away.
Tampa FL
Tampa FL
My wind experience comes from wintering in Arizona for 5 years. I’ve been through wind storms up to 65 mph, definitely not hurricane strength winds but hard enough for me.Hitch up and point the truck into the wind. Have all four stabilizers down tight, if not on concrete, put the plastic pads under the stabilizer pads to help spread the weight.Close all windows and roof vent. I’d also keep the blinds closed just in case something hits the windows.I’d leave the cover on, maybe put a couple of ratchet straps together and strap it under the T@B and over the roof to help keep the cover on.Make sure the fresh water tank is full, and you should have a couple of full propane tanks so you have an escape pod to live in after the storm.
Good luck!Verna, Columbus, IN
*Fill the fresh water tank for ballast.
*Stabilizers down.
*Is your AC vent covered?
*No overhead power lines?
*What are the chances of blown debris impacts in the driveway?
*What about rising water?
*Is your home oriented to act as a windbreak? Our worst winds are usually easterly on the Atlantic coast. You're on the Gulf Coast?
Do your usual preps.
Maybe plan that trip to Yellowstone?
Hang in there when the forecast gets iffy, many of us live out the season with you. Best news is we usually have a week to prepare for a blow, unlike weather events others face.
Edit: ... and do everything @Verna says (was quicker than me with most of the suggestions I made)!
2019 320 Boondock Edge - Sold Jan 20221 -
I have been through several hurricanes in the Caribbean, I would fill both the fresh water and the grey tanks with water, after the storm, just drain the grey tank back out. The more weight down low, the better. I had to contend with flying coconut missiles, at least you do not have that issue. The AC vents should act as a pressure relief valve, allowing the inside of the trailer to equalize air pressure, so leave the AC vents open.
Denny16 said:The AC vents should act as a pressure relief valve, allowing the inside of the trailer to equalize air pressure, so leave the AC vents open.
Really need to disagree about the AC vent not being covered @Denny16. Wind driven water will cause real damage. Hence the phrase' Batten Down the Hatches'. We don't leave our car windows open during storms either. There is no need for pressure equalization.
This is a clip from a National Weather Service PowerPoint on general hurricane safety. A link is posted below the graphic.
https://www.weather.gov/media/chs/misc/HurricaneGuide.pdf
2019 320 Boondock Edge - Sold Jan 20222 -
I would also worry about hail. One time we had warning of a hailstorm. We placed some heavy packing blankets and a large RV rug over the top of our TaB and then used the cover to hold it in place. The hail missed us😁. I like the idea of positioning the car and TaB on the side of the house opposite the wind.Sharon / 2017 T@B CSS / 2015 Toyota Sienna Minivan / Westlake, Ohio1
@CrabTab, good point about driving rain, would put a rain cover over all the vent openings, but not seal them on the bottom side. That said, I have seen Mobil homes flattened by a hurricane passing close enough to create a sudden pressure differential. My house in Puerto Rico only had shutters and jalousie windows, that would flex in the wind and allow pressure differences equalize between inside and outside. The house was designed to withstand a hurricane force storm.
- 30 "FOR SALE" - New/Used Trailers
