Alde 3010-614 blank panel
I have a 2018 Outback edition TAB.  My problem is that the Alde control panel (3010-614) is completely blank.  I was using the Alde this Spring and the power just shut off to the panel.  (I was not in the RV when this happened so I don't know how it reacted when it shut down).
 Question 1- is there a way to test the control panel to see if its receiving power?  I've tried the normal problems, changing the fuses, check plug, check all wirings etc....but nothing seems to work.
Question-2 I don't want to purchase another unit until I know that it is toast! Has any other TAB owners have/had this problem.  How was it solved?
Thanks for you input.
PS:  I have sent Alde two recent emails to their service department but as of today no response from them.
