Hey y'all. Strongly considering getting a 400 as our future camper after determining a 320 variant was too small for our long-term ambitions. We have a Jeep Cherokee Trailhawk with the factory tow package (4500lbs/450lbs) as the potential TV. I wanted to see if anyone with one of the newer 400s has had a look at the real tongue weight of their rigs in various scenarios. Fundamentally the Cherokee's specs fall within the range of capability for what I've calculated out as our likely tongue weight, GVWR, towing capacity, etc. but am curious who has real-world numbers beyond what's on nuCamp's website. Half the point of them making the axle shift was to open up more vehicles to this camper, so I'm wondering if the Cherokee can be one of them.
This is really only relevant to the 2021s that have the axle shifted forward but may also be applicable to the 2020 400 with the Air8, which has a comparable backward weight shift (we don't particularly want that variant).
Also, in before "your vehicle is underpowered, get something beefier".
 We live in a city with a fairly small carport and wouldn't be able to find much of anything else with the Trailhawk's mix of comfort and offroad capability, so that change is not anticipated as being an option. And have searched the site a bit already, but it's always hard to find "Cherokee" by itself without "Grand" being attached, and there are few enough 2021s out there so far that I'd be curious to see direct data from as many members who have these as possible. Thanks in advance!
Can a Jeep Cherokee TrailHawk handle the 2021 TaB 400, I think so, if you keep your gear on the light side (around 500-600 lbs), and keep your driving speeds at 60mph or less. Is it ideal, no, you are getting close to 80-percent of your max capacity, staying at 60-percent is better. That said, Your Jeep is very capable, having the heavier suspension and lower gear ratios over a standard Cherokee. Also driving slower will also save you gas and wear and tear on the Jeep and Trailer. Others are using similar size SUVs to tow their TaB400 trailers.
Portland, OR
The American obsession with towing trailers at 65-70 mph is nuts. Pulling at slower speeds, gives more time to react to emergency situations, and fuel conception is less, and more environmentally friendly. As the song goes, the times are a changing, and we need to change with them. It’s time to slow down and enjoy the trip, as well as the destination.
@Soto, I don't have the newer 400 model per your question but I've been towing my 2018 400 with a V6 Jeep Trailhawk (w/ tow package) for 2 years with no problems so far. I wasn't aware of the shift in the new models but seems to me it at least gives you more adjust ability in tongue weight. I completely agree with the others that weight balancing is very critical so always be sensitive to that. I invested in a tongue weight scale just for peace of mind...just wish I had a full trailer scale. When I owned a 320 I found the light tongue weight was actually causing more of the side to side sway when you get gusts of wind. Simply shifting weight forward was a simple fix for that.
2018 T@B 400 (white w/ red trim)
A trick I have learned going though metro areas is get in the lane where all the trucks are that look like they are passing through, 90%+ of the time you will not end up in a lane that is ending soon. Since everybody seems to want to NOT be in lane following trucks, you can usually leave a decent cushion and no one is eager to jump in that, usually can roll right through metro areas just as fast and way less stress than lane hoping trying to find the lane that is (at the moment) moving faster.
Your 13 MPG is common or less at higher speeds, if you want good MPG, it is a Prius and tent. If you could do it, 45-55 MPH likely will yield best MPG, solo or towing. Would you be shocked if I told you NEW full size semi trucks are very close to 10 MPG with 3-5 times the weight and much more frontal area. They are designed for best MPG loaded. The sad reality is the passenger vehicle industry makes vehicles to get optimum MPG lightly loaded with overdrive gears, load them up and a small SUV gets about as bad as a full size pickup (partially because it can't pull the load with the high gears and then the engine is wound up like a squirrel on meth running on a wheel), even when the full size pickup is towing a much bigger trailer.
As far as dealing with faster traffic, keep in the right hand lane and let those that want to drive faster use the other lanes, and go around you. Driving at 55-60mph with a trailer whilst driving on a 70mph Highway/freeway is not creating a dangerous situation as long as you remain to the right, and allow faster traffic around you. Drive slower, be safer...
At one time in the 70s during the first gas crunch, we had a national max speed of 55mph, given the extra traffic on highways today, a National max speed of 60mph is not a bad idea.
Best is to get in the draft behind a semi and let him pull you a bit. It is a sad reality that there isn't much difference between what I get and even the large trucks pulling the monsters. I still get pretty bad mileage even when I keep right at 55....must just be my destinations. Don't want to go much slower or you start to get in the hazardous range.
