Tab fender flares
RedRaiderRedRaider Member Posts: 11
edited August 2020 in Modifications & Upgrades
I found a couple of threads that discussed the problem with the black plastic fender flares on the Tab Boondock /Outbacks.  It can be difficult to remove a wheel and tire because the flares block access to the fender well.
Has anybody tried to trim the flares?  It looks like they could be trimmed below the keter track to the bottom of the flare.   There’s one screw inside the fender well that supports that portion of the flare, which would no longer be needed.
the bottom corners.
    nüCamp has a new off road Boondock style fender flair they are using on the 2021 trailers, might be a better option than cutting down the existing flairs.   You could also just trim the front and back area of the flair, where it overlaps the tire side, to make tire changes easier.
  • RedRaiderRedRaider Member Posts: 11
    i was planning to trim off the bottom few inches of
    the flare.  Like you said, just the area where they overlap the tires.
  • MuttonChopsMuttonChops Member Posts: 1,778
    IMHO, Once you have removed/installed a wheel you will find the correct angles to allow easy enough access for the task. I've found the task to be A-OK with fenders as is.
  • BaylissBayliss Member Posts: 1,391
    @RedRaider, I agree with @MuttonChops.  Be sure you try removing the tires once before doing any cutting.  My tires/wheels come off easily.  After the lug nuts, try sliding the wheel outward on the spindle and raise the bottom of the tire to get the right angle to slip it off.  It helps to raise the jack sufficiently to add a little extra ground clearance.
