I love long, hot showers. Therefore, I was disappointed to find that the Alde 3020 HE in the 320s does not have Alde Flow. I contacted T@B and they said there was not enough room and they would not do a custom job. I contacted Alde to see how far away the ":Flow" could be from the main unit. After contacting Sweden directly for an answer, the Alde rep said "one meter max". Based on that feedback, it would seem that it should be no problem adding this under the sink in the CS-S as it is adjacent to the 3020 HE. Posted here in case others are curious.
0 ·
Here is the plumbing connection diagram for the Alde and Flo (from Alde EU):
The non return valve connection on the far right goes to the heater registers, which comes off the main Alde boiler from the a Circulation pump when you do not have the Flo, so this connection would need to be moved to the Flo pump connection point.
If you look around online you can findafind install manual. I recommend believing what you read in it and not what you hear from a salesperson or anyone else. There are good instructions and diagrams in it. The diagram in the above post is useful but doesn't actually match the other diagrams or instructions in the manual. The one meter advice sounds like a best guess. If you were to go over it, you would have to extend some of the stock wiring. The water and glycol runs are metric, but the tubing is available a few places.
Not a terrible project on our 400. I too like taking an uncompressed and uncompromised shower. It is well worth the effort.
I got all the parts right from Sugar Creek. The dealers around here would not do this project and they were asking triple the price on the parts.
Just be bold. It can be done.
Reach out if youhyou questions or need a cheerleader.
Whithout hookups, your fresh water availability limits your water use, so the gray tank is about the right size.
@Denny16 (first post of thread) nailed it.
Am sure it could be done but real question is would the effort be worth the return . . . which is more of a concern when the good point of limited T@B 320 Gray Water tankage is considered.
However, really do like the simple concept of the Alde Flow Box.
Adventures: 58 Nights: 405 Towing Miles 50,180
