Has anyone with a 2021 been able to figure out how to install a lock on the plastic exterior storage compartment door. For some unknown crazy reason nucamp decided that two plastic latches with no locks would keep our belongings safe.
The 7/8 inch cam lock that was suggested by another member is too large and will not fit because the cam lock is oval and the hole in the door is round. Any thoughts on solving this issue are appreciated.
Thank you
2021 T@B 400, 2020 Audi Q5
Portland, OR
2 ·
(Alde: 3020; Refrig: Isotherm Cruise 65 Eleg; Battery: BB 100Ah LiFePO4; Solar: Renogy 220W Portable Suitcase; Victron BMV-712; Pwr Cntr: PD-4135KW2B; EMS: PI-HW30C)
cheerw
On the 2021, the outside storage is walled off from the under-bed area...and the access door is really small, so unless you are a truly tiny person, you won't be getting in there!
Tab 400BD
TV: 2013 Lexus GX460
Thant said, as previously discussed, the locks provided on the old doors were common to most RV’s made and not real security, more of a way to keep kids out and contents in during travel.
https://shoprvlocks.com.
