Is there an outlet at the foot of the bed to plug something in besides the TV? Also how far does the TV swing out and is the shelf really all that useful? If anyone could share a pic it would be greatly appreciated.
Under the bed in the Pax side cargo hatch us a 120 VAC shore power outlet. This is at but under the foot of the bed. One could use this outlet add a 120 VAC shore power outlet to the panel at the foot of the bed the inverter outlet uses.
Here is a photo of the TV and the panel at the foot of the bed, this shot is of the foot of the bed area on a 2021 TaB 400.
The access panel under the bed, is the location of the Inverter outlet on the 2018- early 2020 models and is set at a 45-degree angle to the wall and galley cabinet. Here it is as a blank panel, on the 2021 units, with the TV connections behind it.
The shore power outlet on 2018/2019 models is below this panel under the bed, next to the batter cut off switch. The 2021 model setup is shown above.
the 110/120VAC line will be a little more challenging in a 2021 build.
2008 Toyota Sequoia 5.7 L
I just installed this one which has two outlets, two usb A ports and a usb C port with PD for fast charging my Pixel phone.
https://smile.amazon.com/gp/product/B07WLBZFDH/ref=ppx_yo_dt_b_asin_title_o06_s00?ie=UTF8&psc=1
Had to remove two screws from the bracket that holds the kitchen pexiglass divider in order to slip it under, but that took about 1 minute.
Oh, and because NuCamp installs the electrical outlets upside down (to my way of thinking), I had to flip the kitchen outlet so the ground pin is oriented down, not up, due to the angle of the cord on the power strip's plug. Just made for a neater install.
