Second battery into solar port
Can I plug a second battery into the SAE solar port for auxiliary power if my T@B battery is low? I have a 100 watt Renogy suitcase solar, but I'm in for some cold/cloudy weather on my trip and am concerned about power. I have the polarity adapter for my port.
Wisconsinites 2020 T@B 320 S - 2021 Dodge Durango GT Plus TV
  • ScottGScottG Administrator Posts: 5,584
    Assuming your SAE port is wired like mine, doing would be effectively hooking up the two batteries in parallel. This is done frequently as a way to increase battery capacity, and I think it has been discussed here in the past. However, if the two batteries are at different states of charge, they will tend to equalize each other. This may reduce your efficiency somewhat, but to what practical degree is beyond my knowledge. Maybe someone else with actual experience can elaborate.
    Another issue is to make absolute certain that you have the polarity correct, since there is no standard as to which pin carries which leg (+ or -) of the circuit. You are obviously thinking of this since you mentioned an adapter. In any case, be sure to verify the polarity yourself (either visually or by checking continuity) before hooking anything up!
  • Sharon_is_SAMSharon_is_SAM Administrator Posts: 9,855
    Not sure about this, but are the solar port wires large enough to draw power from a secondary battery without heating up?
  • MarkAlMarkAl Member Posts: 500
    I'd replace the existing trailer battery first. To parallel the batteries as ScottG said will to some degree use the fresh battery's energy to recharge the depleted one and then have a smaller amount available for the trailer's need. Ultimately you won't win in this case. It's okay if both are fully charged, but even then with wire losses of the long run the batteries will not work well together, unlike when they have short wires doing it in close proximity....
    managed by VE Smart Network
    IIRC, mine were 10g--large enough for the T@Bs 30A maximum draw.
  • pthomas745pthomas745 Moderator Posts: 4,152
    Ha ha. That's the discussion I was thinking of! I forgot it was one I had started...  :-/
  • MikeDawn265MikeDawn265 Member Posts: 29
    I'll keep ya'll posted on this.
    I leave tomorrow morning for a 10 day, 3 location trip, the first 7 days are non electric. I hope it will not be necessary to do this  :)
    Experience is the best teacher. Good luck!
    Hadn't thought about that, just unbolt the negative terminal on the trailer battery and connect your spare to the solar port (verify the polarity before you connect it!).
    I've figured out my "solar port", checked it with a multimeter  I've rewired SAE cables to have a 12V plug coming from the port.  With a small inverter plugged into the 12v plug,   I've realized there are many things the port can be used for:  running lights around the trailer, power to those little digital antennas, using the little plug in voltmeters for battery monitoring...... It can be a great accessory plug if you think the connections through.
    That works, if the port is connected directly to the battery circuit.  If their is a solar controller between the port and battery than you can only use it for solar panel connections.
    Just confirmed with Creed that the solar port wires are 10 gauge.
    edited September 2020
    Grand, than the wires can carry the current OK, as long as you are not running a larger inverter, or other heavy load source.
