Dropping into 20s tonight
Temps are dipping below freezing tonight and tomorrow night, but coming back to 60 during daytime. I have a trip planned for next weekend, and dont want to winterize just yet.
suggestions as to what to do so nothing gets damaged? Im plugged into shore power and could run the heat.
2019 320s
thanks!
  • jkjennjkjenn Member Posts: 6,413
    edited September 2020
    There have been a few threads about this recently that might help you. Trying searching also using this thread: https://tab-rv.vanillacommunity.com/discussion/11812/winterizing#latest
    Keep the Alde on, and dump the black and gray tanks, leave the valves open and the gate valves open, and for one night you should be fine.  If you have RV antifreeze, than just add that to the black tank. Open the gate valve to get some anti freeze in it and close it back up, so you can continue to use the toilet.  You could do the same for the gray tank too, add some antifreeze in it also.  The rest of the black tank is above the floor in the washroom under the toilet and the Alde will keep it from freezing.
    The issue is the low point black and gray gate valves and drains outside the camper that are as risk.  After the weather warms back up, close the drains and refill the water tank.
