The Avia looks interesting but it is really long. I like the maneuverability of our 2019 Tab 400. Maybe the new model would be 18" longer. Here is what could make me trade:
Dry Bath
Bigger fresh and grey tanks
Cassette toilet option
Factory lithium option
Solar on front and back option
Wider mattress
What do you say?
Jeff & Amy
Now in Manistee, MI
2 ·
A 2-foot add on would get you the dry bath setup, and fore and aft twin/double bunk arrangement, like the 400 Solo without loosing the closet locker, which would work for me.
Jeff & Amy
I'm in the need something between 320 and 400 camp . . . .
2021 T@B Boondock CS-S
2018 Nissan Pathfinder
Ontario, Canada
Jeff & Amy
double axle reduces tongue weight, shifting weight over the dual axles. Looks like a road only setup, not for going rough.
2020 T@B 320 S Boondock Edge: Sm@lls
St Catharines, ON
But really, just bring back the T@da with tanks instead of the cassette. I’d buy one in a heartbeat.
Phil & Anita - Driftless: 2018 T@B 400/2015 Ford Explorer
T@B 510 XL circa 2016 --
This setup would make a sweet 510 for here, with the rear bunks setup for/aft as a twin/queen arrangement. Any left over space could be used in the front dinette area. Water and Alde system would be under the driver’s side bunk, combo outside/inside access storage under pax bunk, and a bench across the back connecting the bunks for a battery locker, like the Solo model is. CoolCat would be under Driver dinette seat as it is on 2018-2019 400 models. Water and holding tanks could be expanded some also. This would be a sweet setup.
http://squob.com/travel_trailers/tb-xl-the-burgher-king/
And this one is closer to our TaB400 in its layout: https://www.youtube.com/watch
Living the Canadian Rockies
Exterior propane hookup is brilliant idea but requires grill modification to actual use it. Provide adaptor maybe so it could be put to use?
I see that NuCamp has cut some corners in the construction of the cabinetry.
2. I don't like the look of the round bathroom sink.
5. Bunk beds are hideous, so I'm glad they are an option.
Nissan Frontier PRO-4X (4.6 liter automatic)
Roof mounted solar panels
NuCamp just confirmed an upcoming T@B 360 !
Will be interesting to see what they come up with .
We couldnt wait any longer for a T@B 500 , so just picked up a 2024 T@B 400 .
2024 NuCamp T@B 400 BD, Charcoal / White
We can’t agree more about the loss of the wardrobe! Bring back the small fridge option!
It is the only major complaint we have about the new 23’s and 24’s.
If NuCamp added a 14in plug between the Bed and the rest of the trailer, it would be so much better. The galley would gain 14in of food prep space, an upper, and lower kitchen cabinet. Next to the refrigerator, you could add a 3ft hanging space for clothes plus 4, 9in drawers. Arc the back slightly higher, about 3in at the center of the bed and two could sit up, snuggled together to watch TV.
Looks like we will probably move to the Max instead.
"Just Enough"
"Just Enough"
