Refrigerator Not Working
This discussion was created from comments split from: 3 way fridge or 12V only fridge in T@B.
  • huanvanho
    huanvanho Member Posts: 48
    I have 2017  T@B 320. My refrigerator is not getting cold after 3 hours plugged in AC. I tried AC, DC and Propane. I have Power indicator light ON for all 3 modes.. BUT refrig. is still not getting Cold. Any comments or idea? Thanks
  • Denny16
    Denny16 Member Posts: 5,431
    @huanvanho, is your trailer level?  If not, that is why the fridge is not getting cold, it needs to be very close to level in both directions.
    pthomas745 Administrator, Moderator Posts: 4,582
    Checked the plug under the sink?
  • jkjenn
    jkjenn Member Posts: 6,423
    This happened when my igniter was corroded.
  • Dalehelman
    Check the fuses on top of the fridge. You have to lift the stove first by loosening the the four corner screws. Ours starts showing temperature drop in about 45 min. Complete cool down in 3-4 hours. On propane or 110 volts.
    1. Hash  T@B Fun
  • jules2go
    jules2go Member Posts: 172
    I'm having a similar issue with my 2020 320s. If you have a GFI outlet near the floor on yours, try resetting. I just brought my camper back from the dealer's service person where it has been for the past week so they could take a look at it. They found nothing wrong, of course! He wasn't sure if that GFI outlet is on the same switch or whatever as the fridge, but maybe that is a source of the problem.
    2020 Tab 320S BE "Moonbeam"
    2019 Toyota Tacoma
    Asheville, NC
    "Don't postpone joy!"
  • llanowar
    llanowar Member Posts: 1
    I have a T@B 400.  Fridge light on but will not cool.  It is level. Took it to repair and worked for them. Took home and worked until I turned dial trim 5 to 3.  Now nothing but light.  Any ideas?
  • Denny16
    edited October 2020
    How old is your TaB400?, if still under warranty, contact nüCamp Warranty Service dept.
  • Dalehelman
    I believe Norcold  fridges have a 2 year warranty.
    1. Hash  T@B Fun
  • Denny16
    edited October 2020
    Yes, and the 2018 TaB400 standard fridge has a Norcold two-way compressor fridge.  Not sure which fridge the llanowar has, are the new TaB400 using an Isotherm Elegance AC/DC fridge?
  • Upasana
    Upasana Member Posts: 5
    The refrigerator in my 2017 Tab 320s stopped working.  Light doesn't even come on indicating power source when attempting to use it with electric or gas.  Battery light will come on if I switch to battery mode.  I had my electrician brother-in-law check it out; there is no problem with electric in the camper, and I switched out the fuse to be sure.  I'm afraid maybe the refrigerator has died.  Any ideas?
  • Verna
    Verna Member Posts: 6,876
    Some history:  Norcold had one three way model used by Pleasant Valley Teardrops in the 2015, 2016 and 2017 T@B 320’s, non CSS models. In the past year there have been many of those who have experienced problems and reported here on the forum.
    Many seem to be soot around the thermocouples, need for cleaning around the thermocouple, and that seems to help a lot for the propane option.
    Now I’m seeing more having problems with the battery operation and electric operation. Battery problems would entail checking the 12V fuses and wiring. Electric would mean to check the 3 glass fuses on top of the fridge (you have to lift of the propane stove to get to said fuses), the circuit breaker, make sure it is plugged in under the sink into the electric outlet, and make sure the GFCI outlet hasn’t tripped.
    A 2016 T@B 320 owner has been told there is no longer a fix. She can either replace with the newer Isotherm two-way (12V and 120V) model with some cabinetry changes, go to an ice cooler, or try fitting an ARB high efficiency 12/120V fridge freezer cooler in its place. There’s even an option of removing the 3-way fridge and making the cabinet into storage and buying  a 12V/120V fridge freezer in the tow vehicle. Get the one with a Danfoos type compressor for longevity.
    I know that’s a lot of options, without a definite solution for you. Norcold has a great Tech Support team, and you should try try them. If they cannot give a solution, then one of the above options are some choices for your fridge needs.
