T@b T2 awning?
Just picked up at 2004 T2 and was wondering if the awnings for the 300 or 400 series fits the older T2's??
Thanks.
Kristen and Bryan
2022 Nissan Frontier 4D 4x4. 2005 T@b T2
Powhatan, Virginia (Just west of Richmond)
2 Canine traveling companions - Luke and Solomon
    ScottG Administrator Posts: 5,693
    I don't think the general size and shape changed much over the years. So, assuming you have a keder rail, I'd bet more than a nickel the standard 320 awning would work just fine.
    Anybody able to confirm this?
    Per PaHaQue Custom:
    • Fits Outback/Boondock and Non-Outback versions of the T@B 320.
  • KB_TAB_T2
    KB_TAB_T2 Member Posts: 31
    i don't have one mounted on the side.. which is where it looks like it attaches? I have one on the top but it is filled with a black rubber/plastic tube?
    Does it connect to the side? or the top?
    Mine also doesn't have trim on the top edges maybe that was a fancy feature or added later?
    Kristen and Bryan
  • Mouseketab
    Mouseketab Member Posts: 1,262
    The trim on the top is for attaching the top to the wall and covering up the screws. The keder rail runs along the side at the top. T2s were the "basic" model and did not have a keder rail.
    Carol
    MOUSE-KE-T@B
    2022 nuCamp T@B 320 CS-S
    Harvest, AL
  • KB_TAB_T2
    Thanks!
    Kristen and Bryan
  • KB_TAB_T2
    edited September 2020
    Is it possible to add a Keder rail? Ours doesn't have one or it was removed at some point.
    —question merged with previous discussion - Verna, T@B Forum Administrator —
    Kristen and Bryan
  • Mouseketab
    The factory can put one in. They have prebent rails. Annealing aluminum is hard.
    There is also this: https://www.sailrite.com/Flex-A-Rail-White-90?gclid=CjwKCAjwwab7BRBAEiwAapqpTGDsCwgZkbwL84j0nKxWzwa5bSgzBK_gaOWH4IRfST59dJRczkNcMBoCjZYQAvD_BwE
    Carol
    MOUSE-KE-T@B
    Harvest, AL
  • VictoriaP
    VictoriaP Member Posts: 1,496
    If I were in a situation without a keder rail, I’d skip it and find a good pop up shelter instead—CLAM and Gazelle make ones that are easy to put up and take down solo.
    As with any time you drill into the sides of the trailer, the mounting screws of a keder rail are another potential spot for water intrusion, and that era of Tab already is prone to rot issues. It wouldn’t be worth the risk to me, not when pop up screen rooms are cheap and and so much easier to put up and take down than they were a decade or two ago.
  • KB_TAB_T2
    Where is the factory?
    Kristen and Bryan
  • KB_TAB_T2
    Thanks that is something to consider.
    The one we bought looks like it had new floor/underlayment put in at some point its Very clean underneath and solid. and so far I have yet to find any soft spots or water damage.
    There are areas where more caulking was put down along the back and front where the shell meets the next piece(not explaining that very well but..) where the Chrome trim separates the pieces
    Kristen and Bryan
  • VictoriaP
    Sugarcreek, Ohio
