Here are photos of all of my modifications I made to our Tab400:
1) Changed out hand crank on the hitch lift to use a 3/4 inch socket in my battery drill to raise and lower hitch.
2) Installed wireless backup camera and wired to license plate lighting wires.
3) Bug screens over out side vents to keep wasps and mice out.
4) Installed Victron Smart Solar controller under bed and ran wiring to plug on outside to connect to a 100 watt Renogy solar panel.
5) Added a step led light with motion detection and a lighted handle. Controlled by two lighted led switches (when in the on position).
6) Changed out the original table with a butcher block table, exact same size but folds down so you can sit without having the table top hit your legs.
7) Installed a two outlet cigarette lighter 12 volt adapter under the dinette cushion for usb chargers and other 12 volt devices.
8) lastly, a BMV712 smart battery monitor with Bluetooth to monitor my battery charge.
https://www.amazon.com/gp/product/B00480BVXS/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Could you please pass along the make and model of the motion activated light, the lighted handle, and your camera?
I like to tinker with our 400 and a motion activated light would be great. I might try to mount it higher so it would light up the door handle as well as the steps.
Also, do you like your camera? There are tons of options. I am not sure which to pick out.
Thanks
Bill
