I have searched the forum looking for an answer regarding actual experience with DC power consumption and factory solar and haven't found what I am looking for. We will be boondocking for 3 days later in the month in a 2020 T@B 400 with factory installed solar. Specifically, given adequate sunshine, how many days could one reasonably expect to have an adequate power supply to run our frig? I know the frig has quite an appetite (12-13amps) so we will be vigilant regarding power usage. I am hesitant to add a generator to our list of essential items to have with us. Your input would be greatly appreciated. Thanks.
2020 T@B 400 w/ factory solar
2015 Nissan Frontier SV, 4WD Crew Cab
Cottage Grove, MN
0 ·
The 3 way frig in the 320 is a DC power hog.
Cottage Grove, MN
Cottage Grove, MN
Fair to say if you're running a 3-way Norcold the best course of action to preserve 12V power supply is once cooled and stocked to the gills (day prior to departing on shore power), run on 12V (or not at all) while enroute. Once camped, shore power (it's already paid for) or propane if no shore power is available. If 12V becomes sole source, be vigilant, shut it down during the night, orient the rig to maximize solar, etc. I suspect you could get by for a good number of days or perhaps weeks if necessary if the weather gods shined on you and you don't do nothin' dumb!
Not much of a boondocker but I'd welcome thoughts from those who are...ya' just never know...
Cheers,
San Diego, CA
www.airbossone.com
managed by VE Smart Network
Between all of our draws (liberal light, fan, water pump usage) we use somewhere in the 35-40 Ah/d range.
We have a 100W solar suitcase that we can move to face the sun through the day, and even with that, in Minnesota, my best charging day so far according to the Victron Connect app has been about 35 Ah. Most days I get closer to 15 Ah, some less. So I’m usually about net minus 20 Ah/d, give or take.
Cottage Grove, MN
I have a 2021 320 Css Boondock and Mine has a 12V only fridge. I observed the frig will cycle on and run for 30 seconds or so and shut off. It does this about every 5 minutes. Does not make sense. We were in very warm weather so probably 75 to 80 degrees at night. Pretty much took the battery down to the point it stoped trying to cool. Does not sound right. What is the behavior of yours durning the night?
