Bathroom Sink
How do you reconnect the bathroom sink drain that has fallen into the space between the sink basin and the bottom shell?
Bill K.
    What model and year trailer?
  • Jody_GeorgeJody_George Member Posts: 2
    I have the same problem as Bill K.  The drain has disconnected and fallen into the abyss in the sink.  Can anyone help with this?  2018 Tab 400
  • NorthIsUpNorthIsUp Member Posts: 194
    @Jody_George The same thing had happened to me. I gave up trying to fish it out. Brought it to uCamp 2019 and got a new-style square sink under warranty, which was a surprise. It might be an expensive fix for you. I'm sure there's a way, but even nuCamp chose to just replace it.
    Jean & Arnie  Nevada
    2019 T@B 400 BL
    2021 Toyota Sequoia 4WD
    You are going to need to remove the entire sink enclosure unit,to get to the drain under the base of the sink unit.  Replacing with the newer 2020/2021 sink unit is another option, or just remove the sink unit and replace with a small standard RV sink, as another TaB400 owner did, or just remove it entirely and put a waterproof plastic panel over the wall to seal the area off.  The last option gives you a larger shower area.
  • HoriganHorigan Member Posts: 805
    Or replace with shelves...  :)
    Rich
    2019 T@b 400
    Bellingham WA
