Pumped Stopped
I am a new T&ab 320 CS-S owner. I ‘be been using KOA full hook ups for a few days and today I don’t hear the pump running.
Beenie
  • nhmike
    nhmike Member Posts: 94
    when hooked up to water, pressure is in the water line, you don’t need the trailers pump.  Your pump should be in the off position.
    2016 cs-s max
    @Beenie, did you fill your fresh tank and also hook up to city water?
  • Denny16
    Denny16 Member Posts: 5,430
    There should be a check valve on the pump, to keep city pressure system from backing into the pump.  Turning the pump on while pressurized, the pump pressure switch should then shut off the pump.  I agree, there is no need to use the pump while connected to a “city” hookup.
  • Beenie
    Beenie Member Posts: 21
    GOT IT! Thank you so much
    pthomas745 Administrator, Moderator Posts: 4,686
    7 month delayed reaction.  But, at least it is all fixed!
