We recently bought a 2019 Tab 400 BDL. On our first trip out the switch on the bathroom fan seemed a bit flaky. I had to push a couple of time to get it to turn off. Back in the driveway, it came on, on its own. The only way I could get the fan to turn off was pulling the fuse.
I haven't had much chance to play with it, but I'm wondering if the switch (a single speed push button) can simply be replaced, or if I'm looking at a whole new fan? I have no issues with the fan, if the switch can be replaced. Has anyone else done this?
https://www.amazon.com/gp/product/B07W4YK1LD/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Chili, NY
2017 Dodge Durango AWD with Tow Package IV
A can of Skyline Chili in the pantry
https://www.amazon.com/gp/product/B07W4YK1LD/ref=ppx_yo_dt_b_asin_title_o09_s00?ie=UTF8&psc=1
but thanks for letting us know its pretty easy to replace.
I'll let you know if/how it works.
Jeff & Amy
Old fuse on left; new fuse on the right. Not exact match, but close enough.
good point. I'll do some more research.
Jeff & Amy
After the warm moist air has been vented, we reset the fan to circulate mode (air blowing down) with the washroom door slightly open, helps to dry the shower curtain very quickly.
2024 Jeep Grand Cherokee 4xe Trailhawk
2021 T@B 400
2019 Subaru Ascent
Took the fan down to replace the switch with one of these:
https://www.amazon.com/gp/product/B07WZLDDLS/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I discovered the switch casing unscrews to reveal the internal spring and contact mechanism, which did indeed have some light corrosion. Cleaned it up with WD40, and it works like new again.
So if you're on the road and the switch stops working, this is a very easy field fix to make.
