I'm hoping I'm not the only one that's ever done this. I was winterizing and cleaning the water pump filter, and while screwing it back on I dropped it. Yeesh. I reach down the opening now and I can feel the floor, but not the filter. Right next to the outside wall at the bottom the floor is not there, it's like it drops further into another area that I can't reach. Anyone have any wisdom around this?
Dean
Adventure Canadian Style
2018 Tab320s Boondock Edition, 2018 Toyota Forerunner TRD
0 ·
@Denny16 Digitaldean appears to have a pre-2021 320. Totally different plumbing from your 400 and a real nightmare of a location to lose anything. Pump is behind the toilet, and the access door is high enough in a very tight space up that it’s nearly impossible to get in there.
You could cut yourself an access panel, but I'd probably start by trying to procure a replacement part first... :-/
